Mathmatic relationship (Linear,Quadratic,Exponential)
In summary: The least-absolute solution can be obtained by solving a so-called linear programming problem:\text{minimize } \sum_{i=1}^8 z_i\\\text{subject to the constraints}\\z_i \geq Y_i - a - b X_i - c X_i^2, \: i=1, \ldots, 8\\z_i \geq a + b X_i + cX_i^2 - Y_i, \: i = 1, \ldots, 8
Ltpenguin
State the mathematical relationship (Linear,Quadratic,Exponential) and determine the regression equation for this relationship.
X| 1 | 3 | 5 | 7 | 9 | 11 | 13 | 15 |
Y| 50 | 14 | 2 | 14 | 50| 50 |194|302|
?.? i input the information into my TI-83 Plus and i get an error when trying to make a regression equation and i cannot figure out the type of relationship it is(linear,quadratic, or exponential)
anyone know how to do a table? i did the difference thing.
Look carefully at the graph.
How does a quadratic graph normally look like?
How does an exponential graph normally look like?
And how does a linear graph normally look like?
If you know all these, then you can answer your question. :wink:
It would appear to be a quadratic but when i try to make the formula on my TI-83 it doesn't make the equation it gives and error.
The ##y## value for ##x=11## seems to be giving the error. Try removing that.
Obviously this is not a linear graph -Linear graphs should be a straight line.
This is also not a exponential graph. Do you know why?
It is a Quadratic because it forms a parabola and not an exponential graph because an exponential graph would not lower at any point it would continune to go on a sharp incline. Also i still got an error when i removed x=11 / y=50
Got another calculator my seems to malfunction when doing the calc. y=ax^2+bx+c A=3.267857 B= -35.357214 c=89.589285
Then your calculator is broken(Or reached some limit?)
My calculator does that without malfunctioning. See:
Likes 1 person
That agrees with adjacent's recent posted value.
If you discard the point with x = 11, the rest of the points lie exactly on a parabola. For this parabola, A, B, and C are all integers.
If there is a context to the problem, you may want to consider that. Sometimes output variables are non-negative. Examples would be height, age, test grades. If that is a constraint on this data set, it may be better to drop the point (11, 50) before running the regression.
Just for confirmation, using all the given points, Maple gives exact fractions:$$
a=\frac {183}{56},~b=-\frac{495}{14},~c=\frac{5013}{56}$$which agrees with the other solutions given as decimals.
Isn't that the parabola of best fit including that ##x=11## point?
None of the points in the table lies in that(Your) parabola
Isn't that what I said above?
You wouldn't expect them to be exactly on the best least squares fit.
When I do it in Maple I get ##a = 183/56, b = -495/15, c = 5017/56##, so my ##c## is a bit different from what you wrote.
If, instead of a least-squares solution we minimize the absolute error solution
[tex] \sum_{i=1}^8 |Y_i - a - b X_i - c X_i^2| [/tex]
we obtain ##a = 77, b = -30,\, c = 3##. The errors are all zero except at the point x = 11, where the absolute error is 60. Basically, the mean absolute-deviation method automatically de-emphasizes the point x = 11 and gives an exact fit to the rest of the data.
For the benefit of the OP: the least-absolute solution can be obtained by solving a so-called linear programming problem:
[tex] \text{minimize } \sum_{i=1}^8 z_i\\
z_i \geq a + b X_i + cX_i^2 - Y_i, \: i = 1, \ldots, 8[/tex]
Here, the variables are ##a,b,c, z_1, z_2, \ldots, z_8##. Such problems can be solved using the EXCEL Solver tool, or using the (free) trial version of LINGO (from LINDO Systems, Inc.) plus numerous free "linear programming solution" tools available from the web.
I just ran it again. Apparently I mistyped the numerator for ##c## because I do get ##5017/56## as you do. But for ##b## I still get ##-495/14##.
I mis-typed ##b##; it should have been as you state.
Related to Mathmatic relationship (Linear,Quadratic,Exponential)
1. What are the different types of mathmatical relationships?
The three main types of mathmatical relationships are linear, quadratic, and exponential. These relationships describe how one variable changes in relation to another variable.
2. How do you determine if a relationship is linear, quadratic, or exponential?
A linear relationship is represented by a straight line when graphed, with a constant rate of change between the two variables. A quadratic relationship is represented by a curved line when graphed, with a changing rate of change between the two variables. An exponential relationship is represented by a curved line that increases or decreases rapidly when graphed, with a constant rate of change between the two variables.
3. What is the difference between a linear and quadratic relationship?
The main difference between a linear and quadratic relationship is the shape of the graph. A linear relationship is represented by a straight line, while a quadratic relationship is represented by a curved line. Additionally, the rate of change in a linear relationship is constant, while the rate of change in a quadratic relationship changes.
4. How do you solve a quadratic equation?
To solve a quadratic equation, you can use the quadratic formula, factoring, or completing the square. The quadratic formula is: x = (-b ± √(b^2 - 4ac)) / 2a, where a, b, and c are coefficients in the equation ax^2 + bx + c = 0. Factoring involves finding two numbers that multiply to equal the constant term (c) and add to equal the coefficient of the middle term (b). Completing the square involves manipulating the equation to create a perfect square trinomial on one side.
5. How are exponential relationships used in real life?
Exponential relationships are used to model situations where the rate of change is constantly increasing or decreasing. They can be used to predict population growth, compound interest, and the decay of radioactive materials. They are also used in fields such as biology, finance, and physics to model natural phenomena.
  • Nuclear Engineering
