Mathtype opening wrong equation
  • Thread starter crw
  • Tags
    Mathtype
In summary, the conversation discusses an issue with MathType 5.2 in Wordperfect 12 where it continues to open an old equation instead of the one clicked. Despite trying various solutions such as copying the equation to a new document, clearing the clipboard, and restarting the computer, the same result persists. The possibility of MathType being fixed on a particular OLE is also mentioned. The individual also mentions trying MathType 6.5 with Wordperfect X4, but found no significant difference. The recommendation is to open MathType, create the equation, and then close the MathType window for best results. Additionally, the suggestion is made to contact the tech support department at Design Science for further assistance.
crw
Using XP and MathType 5.2 in Wordperfect 12. All was working well until Mathtype continued to open an old equation irrespective of the equation clicked. Copying the equation to a new document, clearing (XP) clipboard, restarting WP, restarting the computer, trying to open each of a number of different equations, all produced the same result. It seems that MathType has fixed on a particular OLE and aint going to let it go. Any ideas please?
(Incidentally, and independently of this problem, I have tried MathType 6.5 with WordPrefect X4 but found no significant difference from 5.2 with WP12)
Going off of the information you've given, could it be that you're copying an equation from one place in the document to another, instead of opening the MathType window each time? These steps will consistently give you best results: Open MathType, create the equation, close the MathType window. For the "Open MT" step, you can either go through the Insert > Object dialog, or click the Equation command on the Insert menu, or customize your toolbar to put a button on it to click.
BTW, Design Science (makers of MathType) has a full-time tech support department. Why not give them a chance to help? Send email to support at dessci dot com.
Related to Mathtype opening wrong equation
1. Why is my Mathtype opening the wrong equation?
There could be a few reasons for this issue. One possibility is that the equation you are trying to open is corrupted or was saved incorrectly. Another possibility is that there may be a compatibility issue with the version of Mathtype you are using. It is also possible that there is a glitch or bug in the software itself.
2. How can I fix Mathtype when it opens the wrong equation?
If the issue is due to a corrupted or incorrectly saved equation, you may need to recreate the equation or try opening it in a different program. If the issue is with compatibility, you may need to update your Mathtype software to the latest version. If you suspect a glitch or bug, you can try restarting the program or contacting the Mathtype support team for assistance.
3. Is there a way to prevent Mathtype from opening the wrong equation in the future?
To prevent this issue from happening again, it is important to regularly save your equations and ensure they are saved correctly. It is also helpful to keep your Mathtype software up to date. If you notice any glitches or bugs, report them to the Mathtype team so they can be addressed in future updates.
4. Can I recover a lost or corrupted equation in Mathtype?
If an equation is lost or corrupted in Mathtype, there is unfortunately no way to recover it. It is important to save your equations regularly and backup important equations in case of any technical issues. You may also want to consider using a different program or software to create and save equations.
5. How can I troubleshoot Mathtype when it opens the wrong equation?
To troubleshoot this issue, you can try opening the equation in a different program to see if the issue is with Mathtype or the equation itself. You can also try restarting the program or updating to the latest version. If the issue persists, you may need to contact the Mathtype support team for further assistance.
  • Computing and Technology
10K
  • Sticky
  • Aerospace Engineering
61K
