fluidistic
- 262
I use matplotlib to create files.pgf that I can \include{} in my latex documents. All works nicely, except when I want to make a reference to some equation of my latex document. For example, I when plot several curves on a graph and label them as "Coming from expression ..." where ... is \ref{eq:some_equation}, then I get an error and no file.pgf is produced. If, however, the \label{} of the equation contains no underscore, then there is no problem, the file.pgf is created and can be correctly imported into the latex document.
How can I make matplotlib able to create the file.pgf without removing the underscores? Because then I also have to remove it in all my latex files referencing to that particular equation.
I already tried \_ instead of _, to no avail.
Here might be a MWE (untested):
This MWE should return an error, unless the underscore in heat_eq is removed. Ideally, I want to make matplotlib understand that it can deal with the underscore.
Python:
import matplotlib as mpl
mpl.use('pgf')
import matplotlib.pyplot as plt
x, y = [1], [2]
plt.plot(x, y, label='coming from expr.\\ref{eq:heat_eq}')
plt.savefig('file.pgf')
plt.close()
