Matrices: if AB=A and BA=B, then B^2 is equal to?
  • Thread starter Rikudo
  • Tags
    Matrices
In summary, the two methods give different results because one uses the identity matrix and the other uses a projection.
Rikudo
120
If A and B are two matrices such that AB=A and BA=B, then B^2 is equal to?
(a)A (b)B (c) 1 (d)0
A A^-1= I, where I is an identity matrix
I have a different way in solving the problem, but strangely, the result is different from that written in the solution manual.
My method:
Firstly, we will solve the ##AB=A## equation
$$AB=A$$
$$B=A^{−1}A$$
$$B=I$$
where ## I## is an identity matrix
Similarly, we can solve ##BA=B## using the same method
$$BA=B$$
$$A=B^{−1}B$$
$$A=I$$
where ## I ## is an identity matrix
It can be concluded that matrix ##A=B##. Hence, ##B^2=B=A##, and the answer to the multiple choice question is (a) and (b)Now, let's look at the book's solution:
\begin{align}
B^2 & =BB\nonumber\\\
& =(BA)B\nonumber\\\
& = B(AB)\nonumber\\\
& =BA\nonumber\\\
&=B\nonumber
\end{align}
The answer is (b)I thought that the matrix ##B## is equal to ##A##, but it seems that I am wrong(?)
Why both methods results in different answers?
You assumed the matrices are invertible, but they might not be.
Likes WWGD, robphy, Demystifier and 6 others
Rikudo said:
JNow, let's look at the book's solution:
\begin{align}
& =BA\nonumber\\\
&=B\nonumber
\end{align}
The answer is (b)
There's something not quite right about this problem. That shows that in all cases ##B^2 = B##, but it doesn't show the other answers are wrong. It might turn out to be the case that ##B = I##. In which case ##B^2 = B## also holds.
In fact, it might even be the case that ##A = B = I## is implied by what is given.
Likes malawi_glenn, FactChecker and topsquark
Clearly not, because A=B= projection onto your favorite subspace also works.
I haven't come up with an example where A and B are different though. The fact that ##B^2=B## means B is a projection. ##A## is also a projection. ##AB=A## means that the image of Amust be in the image of B,and we get the other way around, which feels like A and B are projections with the same image and hence are equal, but this analysis might not hold in some corner case where there's no inner product, like if your base field is ##F_p##.
Likes PeroK and topsquark
Neither have I!
Likes topsquark
You will not find any examples of that. A and B are clearly projection operators from A^2 = A and B^2 = B.
This means that they are equal to the identity operator on their image and zero on their kernel (duh!).
By AB = A we know that B is the identity operator on the image of A so ##Im(B) \supseteq Im(A)## and vice versa. Hence ##Im(A) = Im(B)## and both operators have the same image - on which they are both the identity operator.
  • Love
Likes topsquark
A=
\begin{pmatrix}
1 & 0 \\
0 & 0
\end{pmatrix}
B=
\begin{pmatrix}
1 & 0 \\
1 & 0
\end{pmatrix}
Likes Maarten Havinga, malawi_glenn, PeroK and 2 others
The kernels need not be the same.
This is true, but the above makes your argument incorrect.
Given vector space ##V## and a subspace ##W## there is more than one complement. In other words you can have ##V=W_1\oplus W## and ##V=W_2\oplus W## with different complements ##W_1## and ##W_2##. So the two projections onto ##W## will be different. You can project on the x-axis along the y-axis or along a diagonal (or any other slanted line). All have the same image the x-axis, but are different.
Likes malawi_glenn, PeroK, Orodruin and 2 others
Not every projection is an orthogonal projection. It's so obvious once you write it.
Likes martinbn and topsquark
I probably got carried away subconciously thinking of Hermitian operators. Of course, no such requirement is mentioned in the OP. Thank you for the correction.
So to correct this. I believe the argument of the image is still valid. However, the kernel need not be orthogonal to the image so Im(A) = Im(B) = V and A and B being the identity operator on ##V## does not imply that A = B generally. Indeed, if a vector ##u = v_A + w_A = v_B + w_B## where ##v_i## is in ##V## and ##w_A## is in the kernel of ##A## etc, then ##uA = v_A A + w_A A = v_A## and ##uB = v_B B + w_B B = v_B##. If ##w_A \neq w_B## then ##v_A \neq v_B## and therefore ##A \neq B##.
Edit: More generally, the kernel does not need to be the same just because the image is the same. This is where my brain fart appeared.
Likes topsquark
It's a strange way to pose this problem. Charitably, I would phrase it as: if ##AB=A## and ##BA=B##, then ##A,B## are idempotent matrices.
So, if invertibility is assumed, then it can only be the identity and the problem is trivial.
Sure, but that was concluded already in the OP. However, the problem itself states nothing about invertibility.
Hello and sorry for the obvious question but: on this forum when the OP writes "Relevant equations", should we assume that it is given in the problem too or that the OP believes that these are the equations that should be used? Because in this specific case, they constitute an additional assumption that provides a different solution which is a subset of the general solution.
@Amentia
It's a template of some sort. I would consider the problem statement and the proof attempt. Relevant equations are likely an interpretation of the post author and need not be applicable.
@Orodruin
Agreed, but the proof of idempotency is also included in OP. Mathematically, there is nothing else to add.
Likes topsquark and Amentia
Well, of the bat, neither ##A^2## nor ##B^2## may be defined.
But if we have ##A## is ##a\times c##; ##B## is ##b\times d##, and both ##AB, BA## are defined, then ##c=b, d=a##. So ##A## is ##a\times b##,
##B## is ## b\times a##
Since ##B^2## is defined, then##b=a## and both ##A,B## are square.
Seems like pulling teeth. Wonder if OP fully provided conditions of the problem.
Good point. But since AB=A, it follows that A and B have same domain, and also that the range of B is the domain of A, so B is square of dimension equal to the domain dimension of A. Then since BA=B, the same argument shows A is square of the same dimension as B. So the given information does imply both A^2 and B^2 are defined. And you are right that it needs checking.
Likes e_jane and WWGD
I suspect OP left out some of the conditions of the problem.
FAQ: Matrices: if AB=A and BA=B, then B^2 is equal to?
What is the value of B^2 if AB=A and BA=B?
The value of B^2 is equal to B.
How can we prove that B^2 is equal to B if AB=A and BA=B?
We can prove this by using the associative property of matrix multiplication. Since AB=A and BA=B, we can rewrite B^2 as (BA)(BA). Using the associative property, this becomes B(AB)A. Since AB=A, this simplifies to B(A)A. Again, using the associative property, we get (BA)A. Since BA=B, this simplifies to B^2.
Can you give an example of matrices that satisfy the equations AB=A and BA=B?
Yes, for example, consider the matrices A = [1 0; 0 0] and B = [1 0; 1 0]. We can verify that AB=A and BA=B by performing the matrix multiplication.
What is the significance of the equations AB=A and BA=B?
These equations represent idempotent matrices, which are matrices that remain unchanged when multiplied by themselves. This property has various applications in fields such as computer science, economics, and engineering.
Is the statement "if AB=A and BA=B, then B^2 is equal to B" always true?
No, this statement is not always true. It only holds true for idempotent matrices. For non-idempotent matrices, B^2 may not be equal to B even if AB=A and BA=B.
