geoffrey159
- 535
- 72
[/B]
What are the ##n\times n## matrices over a field ##K## such that ##M^2 = 0 ## ?
Please can you tell me if this is correct, it looks ok to me but I have some doubts. I have reused the ideas that I found in a proof about equivalent matrices.
- One possibility is ##M = 0##
- Assume that ##M## represents the linear map ##f: E \rightarrow F## in basis ##{\cal B}## and ##{\cal C}## both with dimension ##n##.
Since ##f^2 = 0##, then ##\text{Im}(f) \subset \text{Ker}(f) ##.
Let ##(e_1,...,e_p)## be a basis of ##\text{Ker}(f)##. This basis can be completed into a basis ##{\cal B'} = (e_1,...,e_p,e_{p+1},...,e_n) ## of ##E##.
The family ##(f(e_{p+1}),...,f(e_n)) ## belongs to ##\text{Im}(f) \subset \text{Ker}(f) ## and is linearly independent in ##F##.- Linear indenpendence :
##\sum_{k = p+1}^n \lambda_k f(e_k) = 0 \Rightarrow \sum_{k = p+1}^n \lambda_k e_k \in \text{Ker}(f) = \text{span}(e_{1},...,e_p) ##, but ##{\cal B'}## being a basis of ##E##, all the lambda's are zero.
- Free families in a vector space have less vectors than a basis of that vector space, so ##n-p \le p \Rightarrow p \ge n/2##. By the rank theorem, ##f## has rank less than ##n/2##
The free family ##(f(e_{p+1}),...,f(e_n)) ## can be completed into a basis ##{\cal C'} = (f(e_{p+1}),...,f(e_n), f_1,...,f_p) ## of ##F##.
So it follows from all this that in the basis ##({\cal B',C'})##, the matrix of ##f## is zero everywhere but in the upper right corner where there is an identity matrix packed somewhere starting at line 1 and ending column ##n##, the somewhere depending upon the rank of ##f##.
-> My answer is 0 and matrices that are similar to a matrix zero everywhere but in the upper right corner, where there is an identity matrix packed somewhere starting at line 1 and ending column ##n##.
