Matrix elements of non-normalizable states
In summary: Bloch wave function with respect to the crystal momentum ##k##. However, since this part of the wave function is not normalizable, textbooks use an alternative normalization condition, leading to difficulties when calculating the matrix elements. The notation for this matrix element can be confusing and it is not easy to define it properly.
taishizhiqiu
63
Although strictly quantum mechanics is defined in ##L_2## (square integrable function space), non normalizable states exists in literature.
In this case, textbooks adopt an alternative normalization condition. for example, for ##\psi_p(x)=\frac{1}{2\pi\hbar}e^{ipx/\hbar}##
\langle\psi_p|\psi_{p'}\rangle=\delta(p-p')
However, it is not easy calculating matrix elements this way. For example, how to calculate
A(k)=i\langle u(k)|\partial_k|u(k)\rangle
##A(k)## is actually berry connection in solid state band theory and ##u(k)## is periodic part of bloch wave function.
Can anyone tell me how to define this matrix elements?
I do not understand your notation, defining ##A(k)##. It simply doesn't make any sense to me. Where does this come from?
According to bloch theorem, wave function in crystals should be like ##\psi_k(x)=e^{ikx}u_k(x)##, where ##u_k(x+a)=u_k(x)## and ##a## is lattice constant.
So ##\langle u(k)|\partial_k|u(k)\rangle## should be something like ##\int u^*_k(x)\partial_k u_k(x)dx##, although it doesn't make sense because this integral is infinite.
##A## is berry connection where the adiabatic parameter is ##k##.(https://en.wikipedia.org/wiki/Berry_connection_and_curvature)This quantity is heavily used in topological insulators
Related to Matrix elements of non-normalizable states
1. What are matrix elements of non-normalizable states?
Matrix elements of non-normalizable states refer to the values obtained when calculating the overlap between two non-normalizable states in quantum mechanics. These states are not physically realizable, but are used in mathematical calculations to represent infinite or unbounded systems.
2. How are matrix elements of non-normalizable states calculated?
The calculation of matrix elements of non-normalizable states involves taking the inner product of two non-normalizable wavefunctions and integrating over all space. This results in a complex number that represents the overlap between the two states.
3. What is the significance of matrix elements of non-normalizable states?
Matrix elements of non-normalizable states are important in quantum mechanics because they allow us to calculate physical quantities such as transition probabilities and expectation values. They also help us understand the behavior of infinite or unbounded systems.
4. How do non-normalizable states differ from normalizable states?
Non-normalizable states have an infinite or unbounded wavefunction, meaning that the probability of finding the particle at any point in space is non-zero. Normalizable states, on the other hand, have a finite and bounded wavefunction, with a probability of 1 for finding the particle within a certain region of space.
5. Can non-normalizable states be observed in experiments?
No, non-normalizable states are not physically realizable and cannot be observed in experiments. They are purely mathematical constructs used in theoretical calculations to describe infinite or unbounded systems. Only normalizable states can be observed in experiments.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
