Matrix method to find coefficients of 1-d S.E.
In summary: The coefficients only go like ##1/n^2## so it converges relatively quickly.In summary, a MATLAB program was used to solve for the eigenvalues and eigenvectors of a matrix equation, using the coefficients to construct a solution for a problem involving a square potential and the Schrodinger equation. The question of normalization for the solution was discussed, with the conclusion that a normalization factor could be applied to ensure the solution is normalized. The use of box eigenstates as a basis for the harmonic oscillator was also mentioned, with some concerns raised about its effectiveness. It was noted that the chosen method produced results that were in agreement with the exact oscillator eigenfunctions.
davidbenari
466
I haven't taken a course on quantum mechanics yet, but I was asked to solve (numerically)
##[-\frac{\hbar^2}{2m}\frac{d^2}{dx^2}+V(x)]\phi(x)=E\phi(x) ##
##V(x)=2000(x-0.5)^2##
by supposing the solution is ##\sum_{0}^{\infty} a_n \phi_n(x)## and ##\phi_n(x)## is the typical solution to the a square potential ##\phi_n(x) = \sqrt{\frac{2}{L}} sin(\frac{n \pi x}{L})##.
Now, to solve this I've done the approximation that my sum is actually a finite sum. Doing some manipulations one can show that you can find coefficients via the matrix equation
##\mathbf{M}\mathbf{a}=E\mathbf{a}##.
where ##M_{mn} = E_m \delta_{mn} + \int_{0}^{L} \phi_m \phi_n V(x) dx##.
And ##E_m= \frac{\hbar^2 m^2 \pi^2}{2 M L^2}##
Now, I've implemented a MATLAB program to solve eigenvalues and eigenvectors for ##\mathbf{M}## and used those coefficients to construct the solution to this problem.
Now, my question is how do I mathematically know ##\phi(x)## is normalized as well? Regarding the eigenvalues ##E##, does QM say that my system can have any of the eigenvalues as energies when I'm not observing? Is that the interpretation?
The vectors ##|\psi\rangle## used in QM (in QM they are usually called 'kets') are normalised by assumption. There can be problems with kets that are based on the Dirac delta function, but the energy eigenfunctions ##|\phi_n\rangle## that are in the above problem are not of that kind.
Your second question can't really be answered without knowing something about the physical system. All we have above is a differential equation, with no initial conditions and no physical description.
I guess you mean ##\phi_n## are normalised by assumption, but I see no mathematical reason that justifies why a linear superposition (that satisfies the DE) of them should also be normalised. Perhaps I didn't understand what you said correctly.
What information would be important to look for here? How does the typical problem statement go? I thought superposition of energy states was relevant to QM.
If ##\phi## is a solution of the DE then so is ##k\phi##, for any complex constant ##k##. So we can just choose the solution ket that has unit norm.
In QM, physical states are mapped to one-dimensional vector subspaces, not to individual vectors (kets). So ##|\psi\rangle## and ##k|\psi\rangle## correspond to the same physical state.
To use the box eigenstates as basis for the harmonic oscillator is a very bad idea! The box is of finite extent, and there the given sine functions are proper square-integrable functions. Of course they are not proper square-integrable functions on the state, where space is over the entire real axis. Here, a good choice for bound state problems can be the harmonic-oscillator energy eigenstates, which you are supposed to calculate. Where does this problem come from, i.e., who "asked you" to do this problem in this quite questionable way?
Likes davidbenari
Absolutely, vanhees71! The original Schrodinger equation is that of a (displaced) harmonic oscillator. Trying to solve it with box eigenstates will not work.
Its a class on computational physics; and it was my professor. To be fair though, I think the method does work since it gave me the correct functions (which I think are Hermite's, right?) I could annex a plot if anyone is interested.
Plus: the method produces 300 coefficients in 0.4 secs, which seems pretty decent. It pretty much ties up with a finite element method. Perhaps this is only true in this case.
vanhees71 said:
The exact oscillator eigenfunctions are Hermite polynomials times a Gaussian:
Yeah I'm pretty sure I got those. My particle is confined to [0,L].
I haven't been able to show if the superposition will be normalized or not. I think andrekirk was implying that I could change the coefficient of my solution (which is true), but I guess it isn't guaranteed the superposition (w/o having to adjust the proper coefficient) will satisfy the normalization condition, which makes sense...
##(\sum a_n \phi_n) ( \sum a^*_n \phi*_n) = \sum \sum a^*_m a_n \phi_n \phi*_m##
Integrating
##\sum \sum a_n a^*_m \delta_{mn} = \sum |a_n|^2 = ?##
Doesn't have to be 1 for sure I guess.
I see, then this is the most simple basis you can choose, and of course you can just multiply your wave function with corresponding normalization factor ##\sqrt{1/\sum_n |a_n|^2}## to normalize it.
Likes davidbenari
I was thinking this shouldn't be too surprising as its very closely related to a Fourier sine series and this gives pretty good convergence to a lot of functions.
FAQ: Matrix method to find coefficients of 1-d S.E.
1. What is the "Matrix method" used for in finding coefficients of 1-d S.E.?
The Matrix method is a mathematical approach used to find the coefficients of a one-dimensional system of equations (1-d S.E.). It involves representing the system of equations in matrix form and using various techniques such as Gaussian elimination or Cramer's rule to solve for the unknown coefficients.
2. What are the advantages of using the Matrix method over other methods?
The Matrix method is advantageous because it allows for a more efficient and organized way to solve systems of equations. It also provides a systematic approach to finding solutions, making it easier to identify errors and make corrections. Additionally, the Matrix method can be easily extended to solve systems of equations with any number of variables, unlike some other methods which may have limitations.
3. Are there any limitations to the Matrix method?
One limitation of the Matrix method is that it can be computationally intensive for large systems of equations. Additionally, the method may not always yield a unique solution, especially if the system is inconsistent or has dependent equations. In such cases, other methods may be more suitable for finding the coefficients.
4. How is the Matrix method used in real-world applications?
The Matrix method has various real-world applications, especially in fields such as engineering, physics, and economics. It is commonly used to solve systems of linear equations in circuit analysis, structural analysis, and optimization problems. It is also utilized in data analysis and statistical modeling, such as in regression analysis.
5. Can the Matrix method be extended to solve higher-dimensional systems of equations?
Yes, the Matrix method can be extended to solve systems of equations with any number of variables (n-d S.E.). However, as the number of equations and variables increases, the computational complexity also increases. Therefore, other methods may be more efficient for solving higher-dimensional systems of equations.
