Matrix of orthogonal projection
So, what does P2 mean in terms of projections?In summary, we are asked to find A^2, the matrix of an orthogonal projection, in two ways. First, by considering the geometric interpretation of applying an orthogonal projection twice. And second, by using the formula A^2 = Q^2 (Q^T)^2, where Q is the matrix of the orthogonal projection onto the subspace V.
morsel
30
Let A be the matrix of an orthogonal projection. Find A^2 in two ways:
a. Geometrically. (consider what happens when you apply an orthogonal projection twice)
b. By computation, using the formula:
matrix of orthogonal projection onto V = QQ^T, where Q = [u1 ... um]
I have no idea how to approach (a).
(b). A^2 = Q Q^T Q Q^T = Q^2 (Q^T)^2
Thanks in advance.
Let's start with (a).
Suppose we have 2 dimensions and A defines an orthogonal projection.
This means that any point v is projected orthogonally on a line.
What happens to this projection if we project it again on the line?
Does it go back to the original point?
We can find on wikipedia a page http://en.wikipedia.org/wiki/Projection_%28linear_algebra%29" :
The transformation P is the orthogonal projection onto the line m.
and:
"In linear algebra and functional analysis, a projection is a linear transformation P from a vector space to itself such that P2 = P. "
Related to Matrix of orthogonal projection
1. What is a matrix of orthogonal projection?
A matrix of orthogonal projection is a square matrix that is used to project vectors onto a subspace in a way that preserves the angles between them. It is often used in linear algebra and geometry to simplify calculations.
2. How is a matrix of orthogonal projection calculated?
A matrix of orthogonal projection is calculated by taking the inner product of the basis vectors of the subspace and constructing a matrix with those values. This matrix is then multiplied by the original vector to project it onto the subspace.
3. What is the purpose of a matrix of orthogonal projection?
The purpose of a matrix of orthogonal projection is to simplify calculations when working with vectors and subspaces. It allows for the projection of a vector onto a lower dimensional subspace, making it easier to solve problems in linear algebra and geometry.
4. What is the difference between a matrix of orthogonal projection and a regular projection matrix?
A matrix of orthogonal projection is a special type of projection matrix that is used specifically for orthogonal projections. Unlike regular projection matrices, it is not necessarily symmetric and may not have eigenvalues of 0 or 1.
5. Can a matrix of orthogonal projection be used for non-orthogonal projections?
No, a matrix of orthogonal projection is only applicable for orthogonal projections. For non-orthogonal projections, a regular projection matrix or other methods may be used.
