Matrix of rotated elements (stiffness matrix)
In summary, the conversation was about the derivation of a matrix for rotating between two different bases. The rotation matrix with a positive angle theta was provided, but there was confusion about the inverted signs. It was suggested to consider the transposition of the matrix, which would flip the negative signs. It was also mentioned that the matrix is orthogonal, so it is important to determine which one is the original and which one is the inverse.
Amaelle
310
54
Good day All
I have a doubt regarding the derivation of the following matrix
according to my basic understanding we want to go from the basis u1 v1 u2 v2 to the basis u'1 v'1 u'2 v'2, and for doing so we use the rotation matrix
the rotation matrix is the following and the angle theta is positive
but i still can 't understand why the signs are inverted?
any help would be highly appreciated
Many thanks in advance!
I'm not sure what the "stretch k" and some other symbols on here are referring to, but you may consider what happens if you multiply each side by the transpose of your matrix. Transposition 'flips' the negative signs that seem out of place here. The matrix is orthogonal, so you may just be missing which matrix is the "original one" and which one is the inverse.
Likes Amaelle
Thanks a lot!
Related to Matrix of rotated elements (stiffness matrix)
1. What is a stiffness matrix in the context of mechanics?
A stiffness matrix is a mathematical representation of the structural stiffness of a system. It is a square matrix that relates the forces applied to a system to the resulting displacements, taking into account the material properties and geometry of the system.
2. How is a stiffness matrix affected by rotations of elements?
The rotation of elements can affect the stiffness matrix by changing the orientation of the structural components. This can alter the way forces and displacements are related, and therefore affect the stiffness of the system. A rotated element may have a different stiffness matrix than an unrotated one.
3. What is the significance of a rotated stiffness matrix in structural analysis?
A rotated stiffness matrix is important in structural analysis because it allows for the accurate modeling of real-world structures. Many structures are not perfectly aligned in a single plane, and taking into account the rotations of elements allows for more precise calculations of forces and displacements.
4. How is a matrix of rotated elements used in finite element analysis?
In finite element analysis, a matrix of rotated elements is used to calculate the stiffness of a system and solve for the displacements and forces at various points. By incorporating rotations, the model becomes more accurate and can better represent the behavior of the physical system.
5. Can a stiffness matrix be used for non-linear systems?
Yes, a stiffness matrix can be used for non-linear systems by using iterative methods to solve for the displacements and forces. However, in non-linear systems, the stiffness matrix may change based on the displacement, making the analysis more complex. In these cases, a linearized stiffness matrix may be used as an approximation.
  • General Engineering
  • Mechanical Engineering
  • Mechanics
