Matrix Representation of Jₐ for j=1
In summary, the operators J-hat(subscript +) and J-hat(subscript -) are defined in terms of the Cartesian components of angular momentum J-hat and can be used to obtain the matrix representation of J(subscript y) for the state with j=1. The ordered basis for j=1 is |1 1>, |1 0>,|1,-1> and the corresponding states in vector representation are given. The Jz operator is diagonal in this representation with the diagonal elements being the possible m-values. For spin j, the diagonal elements of Jz are the possible m-values going from m=j to m=-j in integer steps.
blueyellow
The raising and lowering angular momentum operators, J-hat(subscript +), J-hat(subscript -) are defined in terms of the Cartesian components J-hat(subscript x), J-hat(subscript y), J-hat(subscript z) of angular momentum J-hat by J-hat(+)=J-hat(x)+iJ-hat(y) and J-hat(-)=J-hat(x)-iJ-hat(y).
Obtain the matrix representation of J(subscript y) for the state with j=1 in terms of the set of eigenstates of J-hat(subscript z).
J(subscript y)=(-i/2) (0 sqrt 2 0)
(-sqrt 2 0 sqrt 2)
(0 -sqrt 2 0)
I don't know why though. And what does it mean why 'in terms of the set of eigenstates J-hat(z)?
I had trouble typing out the matrix properly
it is supposed to be:
(0 sqrt2 0)
(-sqrt2 0 sqrt2)
(0 -sqrt2 0)
its the 'in terms of the set of eigenstates of J-z' that confuse me. If it wasn't for those words at the end I might almost be able to do the question. So what do I do? Find the matrix representation of J (y) normally, and then operate with J(y) onto J(z) and then find its eigenvalue, and those eigenvalues are the eigenstates? I tried to operate with J(y) onto J(z) but got nowhere. I feel like I have no idea what I am doing. Please help.
I copied this somewhere from the internet:
the ordered basis is:
|1 1>, |1 0>,|1,-1>
The matrix representation of the operator J(z) in the ordered basis is:
J(z)=
<1,1|J z|1,1> <1,1|J z|1,0> <1,1|J z|1,-1>
<1,0|J z|1,1> <1,0|J z|1,0> <1,0|J z|1,-1>
<1,-1|J z|1,1> <1,-1|J z|1,0> <1,-1|J z|1,-1>
since the basis sets are eigenstates of J z
J z=
1 0 0
0 0 0
0 0 -1
but how did they get:
1 0 0
0 0 0
0 0 -1??
please help
The basis (the possible values for m) for j=1 are m=-1,0,1. Write the corresponding states in vector representation as
[itex]
m=-1: \hspace{2cm} \begin{pmatrix}1 \\ 0 \\ 0 \end{pmatrix} \\
m=0: \hspace{2cm} \begin{pmatrix}0 \\ 1 \\ 0 \end{pmatrix} \\
m=1: \hspace{2cm} \begin{pmatrix}0 \\ 0 \\ 1 \end{pmatrix}
[/itex]
The Jz operator is diagonal in this representation and has these as eigenvectors. The diagonal elements will simply be the possible m-values (that is, m=-1,0,1), giving the matrix you asked about.
In general, for spin j, the diagonal elements of Jz are the possible m-vales, going from m=j to m=-j in integer steps.
FAQ: Matrix Representation of Jₐ for j=1
1. What is a matrix representation?
A matrix representation is a way of representing mathematical objects, such as vectors or operators, using matrices. It involves assigning each element of the object to a specific position in a matrix, which allows for easier manipulation and calculation.
2. What is Jₐ for j=1?
Jₐ is a mathematical operator often used in quantum mechanics to represent the total angular momentum of a particle. When j=1, it indicates that the particle has a spin of 1, meaning it has three possible states: spin up, spin down, or spin neutral.
3. How is Jₐ for j=1 represented in a matrix?
Jₐ for j=1 can be represented in a 3x3 matrix, with each element representing a specific spin state. The diagonal elements represent the spin neutral state, while the off-diagonal elements represent the spin up and spin down states.
4. What is the significance of the matrix representation of Jₐ for j=1?
The matrix representation of Jₐ for j=1 allows for easier calculation and manipulation of the total angular momentum operator. It also provides a way to visualize and understand the different spin states of a particle with a spin of 1.
5. How is the matrix representation of Jₐ for j=1 used in scientific research?
The matrix representation of Jₐ for j=1 is often used in quantum mechanics and particle physics research to understand the behavior of particles with a spin of 1. It is also used in the development of quantum computing and quantum information technologies.
