Matrix Transformation - mappings of functions
Keep up the good work!In summary, the correct matrix transformation for y = \frac{1}{x} onto y = \frac{-1}{3x-1}-2 is:\begin{bmatrix}x'\\y'\end{bmatrix}=\begin{bmatrix}-3 & 0 \\0 & 1\end{bmatrix}\begin{bmatrix}x\\y\end{bmatrix}+\begin{bmatrix}-2\\-1\end{bmatrix}
Kenny52
I need to find the matrix transformation of \(\displaystyle y = \frac{1}{x}\) onto \(\displaystyle y = \frac{-1}{3x-1}-2\)
I think its \(\displaystyle
\begin{bmatrix}
x'\\
y'
\end{bmatrix}
=\begin{bmatrix}
3 & 0 \\
0 & -1
\end{bmatrix}
\begin{bmatrix}
x\\
y
\end{bmatrix}
\begin{bmatrix}
-1\\
-2
\end{bmatrix}
Mathematics news on Phys.org
Great start! However, I believe there may be an error in your matrix transformation. The matrix you provided would result in the transformation y' = 3x + 1, which is not equivalent to y = -1/(3x-1) - 2.
After some calculations, I believe the correct matrix transformation should be:
\begin{bmatrix}
x'\\
y'
\end{bmatrix}
=\begin{bmatrix}
-3 & 0 \\
0 & 1
\end{bmatrix}
\begin{bmatrix}
x\\
y
\end{bmatrix}
\begin{bmatrix}
-2\\
-1
\end{bmatrix}
This transformation would result in y' = -1/(3x-1) - 2, which is the desired outcome. It's important to double check our calculations, especially when dealing with complex equations. Great job on finding the correct transformation!
FAQ: Matrix Transformation - mappings of functions
What is a matrix transformation?
A matrix transformation is a mathematical operation that involves mapping a set of input values to a set of output values using a matrix. It is commonly used in linear algebra and computer graphics to manipulate and transform data.
How is a matrix transformation represented?
A matrix transformation is typically represented by a matrix, which is a rectangular array of numbers. The dimensions of the matrix depend on the number of input and output values. For example, a 2x2 matrix can be used to transform 2-dimensional data, while a 3x3 matrix can be used to transform 3-dimensional data.
What is the purpose of a matrix transformation?
The purpose of a matrix transformation is to change the shape, size, or orientation of a set of input values to produce a set of output values. This can be useful in various applications, such as rotating an image, scaling an object, or performing calculations on a set of data.
What are the types of matrix transformations?
There are several types of matrix transformations, including translation, rotation, scaling, shearing, and reflection. Translation involves shifting an object along a certain direction, while rotation involves rotating an object around a fixed point. Scaling changes the size of an object, shearing stretches or skews an object, and reflection produces a mirror image of an object.
How is a matrix transformation applied to a function?
A matrix transformation can be applied to a function by multiplying the function's coefficients with the transformation matrix. This results in a new function that has been transformed according to the specified matrix. The transformed function will have the same general shape as the original function, but with different values for the coefficients.
