Max. Applied force on outside wall of spinning drum
In summary, the conversation discusses the calculation of maximum pressure caused by centripetal force on the outer ring of a rotating drum filled with water. The outer radius and velocity of the drum are provided, along with calculations for finding the maximum force at a 12" depth using the equations for pressure and centripetal force. There is also a discussion about accounting for the rotation and variable water level height. Ultimately, the conversation concludes that the additional pressure due to rotation is negligible.
mpf
I have a 36" OD aluminum drum within another 48" OD aluminum drum creating 6” channel between the two diameters. The total height of the drum assembly is 16” This design project that I am working on requires me to fill this channel up with 12” of water which equates to about 342.5 lbs of water. I am going to spin this drum at 17.91 RPM which equates the outside radius (24”) to have a tangential velocity of 3.7483 ft/s. Now to my question…..I am looking for the maximum pressure caused by the centripetal force on the outer ring of the drum while the drum is spinning. Logically the maximum force will be at the 12 depth mark because that’s where the most amount of pressure is located.
My way of doing it: I found the ambient pressure at a 12in depth which was 0.43363psi. From the f=pa eq. I then picked an area at the bottom of the drum which was 6” wide (channel width) x 1” giving me an area of 6 in^2. Took the f=pa eq. and multiplied it by the ambient pressure at 12” and got 2.60178 lbs. Plugged that into the f=ma eq. to get my weight given that area and got .0808lbs. Put that bad boy into the centripetal force eq. given my tan. Velocity which is 3.7483 ft/s and the radius which is 2ft and got .5674lbs of force at any location around the outside of the drum at a 12” depth. I know the load is a distributed load so you can solve with an integral for the whole drum wall or use a finite elemental analysis program to solve it but I tried to cut corners and get a ball part estimate. Can someone either validate this or tell me I’m way wrong and help me out. Thanks much
My way of doing it
Where does centripetal force appear?
Every element of mass dm adds ##\omega r^2 dm## to the total force acting on the outside, which is just (pressure)*(surface area).
So are you saying my way strategy was incorrect? I'm just a little confused how to apply your response.
Thanks
I don't understand what you did. In particular, I don't understand how you accounted for the rotation of the setup.
Another issue: Did you consider the variable water level height?
I basically found an area of water at the 12" depth and, found its mass and used that mass in the centripital force eq. Used my tan. velocity of 3.7 ft/s at the 24" radius and solved for centripital force. And I did not consider varaible water level height because I am looking for a ball park estimate. I calculated earlier that the max water level will be around 13.1" so I guess I could use that instead of my 12" h.
Again, I don't think this is the correct way to go about this problem, it's just the only way I thought might work so if you have any ideas how to solve please help.
Thanks
Let's see:
Outer radius 61cm, outer velocity 1.14m/s, outer acceleration 2.14m/s^2 or about 1/4 g. Ok, let's neglect the different water locations due to a different water level.
If we consider some small segment, all relevant forces are inwards/outwards only. In the same way, it is possible to consider the whole water, just with radial forces.
Without rotation, average pressure on the wall outside is same as pressure in a depth of 6'' or 15.25cm, this gives about 1500N/m^2, increasing from 0 to 3000N/m^2 from the surface to the bottom.
With rotation, water at a radius of r feels a force of ##r \omega^2## outwards. Integrating over the whole volume, this gives
$$\int_r^R \rho r'^2 \omega^2 dr' = \frac{1}{3} \rho \omega^2 (R^3-r^3)$$
Using r=45.72cm as inner radius, this gives 154N/m, to distribute over 2*pi*R, therefore I get an additional pressure of 40N/m^2. Hmm, looks negligible.
Terrific, thank you
Related to Max. Applied force on outside wall of spinning drum
What is the purpose of studying the maximum applied force on the outside wall of a spinning drum?
The maximum applied force on the outside wall of a spinning drum is an important factor in understanding the structural integrity and safety of the drum. This force can affect the stability and durability of the drum, and can inform design decisions for various applications, such as industrial mixers or centrifuges.
How is the maximum applied force on the outside wall of a spinning drum calculated?
The maximum applied force on the outside wall of a spinning drum is calculated by considering the angular velocity of the drum, the mass of the contents inside, and the radius of the drum. This can be represented by the equation F = mω²r, where F is the force, m is the mass, ω is the angular velocity, and r is the radius.
What factors can influence the maximum applied force on the outside wall of a spinning drum?
The maximum applied force on the outside wall of a spinning drum can be influenced by several factors, including the speed of rotation, the mass and distribution of the contents inside the drum, and the material and thickness of the drum wall. Additionally, external forces such as vibrations or impacts can also affect the maximum applied force.
How does the maximum applied force on the outside wall of a spinning drum impact the design and materials used?
The maximum applied force on the outside wall of a spinning drum is an important consideration in the design and material selection for the drum. The force must be within the structural limits of the drum to prevent deformation or failure. Additionally, the material used for the drum must have sufficient strength and durability to withstand the maximum applied force.
What are some potential applications for understanding the maximum applied force on the outside wall of a spinning drum?
The maximum applied force on the outside wall of a spinning drum has various applications in industries such as manufacturing, pharmaceuticals, and food processing. It is crucial for designing safe and efficient equipment, such as mixers, centrifuges, and dryers. It can also be used in research and development to optimize processes and improve product quality.
  • Mechanical Engineering
