Max Clock frequency with a Flip-Flop
In summary, the maximum clock frequency for two identical J-K flip flops linked together is determined by the prop delay and setup time specified in the data sheets. The minimum prop delay must not be shorter than the hold time requirement, and the maximum clock rate is limited by the delay of the second FF and the worst-case setup time of the second FF. After creating timing diagrams and using an algebraic approach, the maximum clock frequency is determined to be 7 nanoseconds.
Number2Pencil
208
I need to know the max clock frequency of two identical J-K flip flops linked together (the first flip flop has HIGHs running into its inputs, and the second flip flop has the outputs (Q and Q bar) running to its inputs). They share a common clock.
The data sheets say the prop delay (low to high and high to low) is 5 nano seconds, and the set-up time is 2 nano seconds. the max frequency is usually just given, but this time it's not.
would it be 1/5nano seconds, 1/2 nano seconds, or 1/7 nano seconds?? I can't figure it out...
There will be a setup and hold time specified for the FFs, as well as propagation delays from input to output. If you draw a timing diagram, you will need to ensure that the setup and hold times are met for both FFs. So if they are linked in series, the output of the 1st FF must not change before the hold time of the 2nd FF is met. So the minimum prop delay through the first FF must not be shorter than the hold time requirement of the 2nd FF. And the max clock rate is limited by the delay of the 2nd FF and the worst-case setup time of the 2nd FF.
EDIT -- fixed a couple typos
so combining what you said with what I have:
--Qa must not change faster than 2 ns
--the minimum prop delay through 1st must not be shorter than hold time. True: prop delay = 5 ns, hold time = 2 ns
--max clock rate = 5 ns...worst-case: max clock time = 2 ns
so the maximum clock rate would be 2 ns?
No. You need the data to get through the first FF and be stable for the setup time before you can provide the next clock edge that will clock the FFs (whichever it is that clocks the flop, rising or falling).
after making some timing diagrams, I tried a little algebraic approach:
clock peroid - 5ns >= 2ns
clock peroid >= 7ns
Looks right to me, at least for a straghtforward hookup of two FFs. Good job.
FAQ: Max Clock frequency with a Flip-Flop
What is the definition of "Max Clock frequency with a Flip-Flop"?
The maximum clock frequency with a flip-flop refers to the highest frequency at which a flip-flop can reliably store and transmit data. This frequency is determined by the propagation delay of the flip-flop and the setup and hold times of the incoming data signal.
What factors can affect the maximum clock frequency with a Flip-Flop?
There are several factors that can affect the maximum clock frequency with a flip-flop, including the technology used to manufacture the flip-flop, the operating temperature, the voltage supply, and the characteristics of the input signal.
How is the maximum clock frequency with a Flip-Flop calculated?
The maximum clock frequency with a flip-flop is typically calculated by taking the inverse of the sum of the propagation delay and the setup time of the flip-flop. This calculation can be affected by factors such as the type of flip-flop and the specific circuit design.
Why is it important to consider the maximum clock frequency with a Flip-Flop?
The maximum clock frequency with a flip-flop is an important consideration in digital circuit design because it determines the speed at which the circuit can operate reliably. A higher maximum clock frequency allows for faster data processing and can improve overall system performance.
How can the maximum clock frequency with a Flip-Flop be improved?
The maximum clock frequency with a flip-flop can be improved by using advanced flip-flop designs, optimizing the circuit layout and routing, and adjusting the operating conditions such as voltage and temperature. Additionally, using higher quality components and reducing noise in the circuit can also help improve the maximum clock frequency.
