Max dimensions of box template
In summary: summary, the largest rectangular box with a square base and no top that can be made from out of $1225 in^2$ of material can be made from a cube.
karush
MHB
3,269
find the dimensions of the largest rectangular box with a square base and no top that can be made from out of $1225 in^2$ of material.
well, this might be over simplified but since the volume is max of cube to the a surface area I thot making a cube out of the material would be max volume assuming that is what they mean by largest rectangular box.
since the $\displaystyle\sqrt{1225} = 35$ then $\frac{35}{3}$ would be the length of the side of the cube and to cut the material accordingly. $x$ being the side.
I thot to that usually one can get a max value with a parabola but the vertex of $9x^2$ is $0$ there is no book answer for this...mostly making sure I understand the question correctly... thanks ahead...
EDIT: I don't think that this interpretation of the problem is correct. It should be made from one sheet of material that is cut and folded up to make the box. The diagram you drew has pieces cut out from it, so the below assumes your interpretation but I'm not sure.
Max/min problems like this always follow the steps of first writing an expression with 2 variables and then making a substitution to get it to just 1 variable. From that point you then differentiate and find the solution.
Let's say the square base has length x and width x. The height of the box is unknown so let's call that y. You are also correct that we need to use surface area now. The total surface area must be 1225, so let's express that in terms of x and y. There is the base and 4 sides of the box. The base uses $x^2$ square inches and each side uses $xy$ so all 4 use $4xy$. That brings the total to $x^2+4xy=1225$
Solving that for y we get \(\displaystyle y=\frac{x^2-1225}{4x}\). Now we look at the volume of the box $x^2y$ and plug in the previous equation for y to get the whole thing in terms of 1 variable.
See where that takes you.
EDIT2: This is supposed to use calculus I believe. You were given this problem in your calc course, correct?
so you are saying that
$\displaystyle x^2\left(\frac{x^2-1225}{4x}\right)= \frac{x^3-1225}{4}=V$
when that graphed as a cubic function the rel max is little over $4000$
actually yes I am in calc but this was given as an algebra 2 problem just someone I am trying to help, but didn't know how to put this in algebra terms. So apparently this may not be a cube for max V
I know that the y' = 0 will give min/max
True, unless you, karush, happen to be very good at maximizing cubic polynomials without calculus. Incidentally, to finish this problem, I think you're going to need the boundary limits, because taking the derivative $dV/dx$ and setting it equal to zero finds a nice minimum.
Careful. I think the $1225$ needs an $x$ multiplier.
$\displaystyle x^2\left(\frac{x^2-1225}{4x}\right)$=
$\displaystyle =\frac{x^3-1225x}{4}=V$
yep saw that, thanks,
well the only way I know to find max with algebra
is to find midpoints between the zeros
then find $f(x)$ if it is + then it is max
kinda messy process
Well, as I said in Post # 4, taking the derivative and setting it equal to zero finds, in this case, a local minimum. To find the max, you're going to need to find some sort of boundary conditions, and try to evaluate the volume at the extremes.
Yep, my mistake earlier. The maximum volume is desired.
For the boundary condition, use the fact that \(\displaystyle x^2 \le x^2+4xy\) assuming $x \ge 0$ and using $x^2+4xy=1225$.
whoa lost you there not familiar with boundary conditions...
y' I got $\frac{3x^2}{4}-\frac{1225}{4}$
What happens when you set that equal to 0? What do you find? A local maximum or local minimum?
we are left with $-\frac{1225}{4}$ which is as mentioned a min but the cubic graph also shows a max at around 4125
Correct, and that's a problem. If x = 4125 then when you plug that into the surface area formula you see that you don't have enough material. So the min/max method won't work here. You need to set up boundaries.
Because $x>0$, \(\displaystyle x^2 \le x^2+4xy\) and the part on the right hand side is 1225 so that's the same as \(\displaystyle x^2 \le 1225 \rightarrow x \le 35\).
So in general, $0 \le x \le 35$. What do we see about the graph of the volume function in this domain?
we are left with
$-\frac{1225}{4}$ which is min
however are we including the cutout of corners of a fixed square of material
which will alter the SA
karush said:
we are left with
I assumed your interpretation of the problem was that this wasn't cut out from anything. That's why the surface area is $x^2+4xy$. In real world applications you don't have access to shapes like this without cutting something out so often this problem is given with the assumption you have to cut a rectangular sheet to make the box.
There is something I seem to have missed because on the domain of [0,35] the volume is negative so none of those values work. Maybe someone else can jump in a figure out what's going on?
I suggest that karush post the original problem exactly as given, word-for-word. We can go from there.
OK, could we close this thread, I will restate the original question in a new post, although looks like what I have is correct in the original question of the OP. basically we are making a box out of 1225 sq in of material and looking max volume. at least that what it seems to be asking.,
sorry, didn't mean to take everyone for a walk in the woods...(Movie)
FAQ: Max dimensions of box template
What are the max dimensions of a box template?
The max dimensions of a box template can vary depending on the type of box and the material used. However, a common rule of thumb is that the length plus width plus height should not exceed 165 inches for shipping purposes.
Can a box template be customized to fit specific dimensions?
Yes, box templates can be customized to fit specific dimensions. This can be done by adjusting the measurements of the template or by creating a custom template from scratch.
What materials are commonly used for box templates?
The most commonly used materials for box templates are cardboard, corrugated cardboard, and paperboard. However, other materials such as plastic, wood, and metal can also be used depending on the purpose of the box.
Are there any restrictions on the design of a box template?
There are no specific restrictions on the design of a box template, but it is important to consider the strength and durability of the box when designing it. It is also important to follow any guidelines or regulations for shipping if the box will be used for that purpose.
How can I ensure that my box template is structurally sound?
To ensure that your box template is structurally sound, it is important to use proper measurements and proportions. The flaps and tabs should also be designed to interlock and provide stability. It is also helpful to test the template by creating a prototype before mass production.
