MHB Max Horizontal Displacement of Projectile and its Velocity at T
The equations for the projectile's motion are defined as x = v_0 cos(α_0) t and y = y_0 + v_0 sin(α_0) t - (1/2) gt², where v_0 is the initial speed, α_0 is the launch angle, and g is the acceleration due to gravity. The maximum horizontal displacement of the projectile, when it hits the ground, is given by the formula x_max = v_0² / (g tan(α_0)). At the time T when the projectile reaches the ground, the angle between the initial velocity vector and the velocity vector at T is π/2. Additionally, the optimal launch angle for maximum horizontal range can be calculated as α_0 = arctan(v_0 / √(v_0² + 2gy_0)). This analysis provides essential insights into projectile motion dynamics.
Theia
Let $$x = v_0\cos \alpha _0 t$$ and $$y = y_0 + v_0 \sin \alpha _0 t - \tfrac{1}{2} gt^2$$, where
  • $$v_0$$ is speed at time $$t = 0$$,
  • $$\alpha _0$$ is the angle between positive $$x$$-axis and initial velocity vector ($$\alpha _0 \in (0, \pi/2)$$),
  • $$t$$ time in seconds,
  • $$y_0 >0$$ the $$y$$ coordinate at time $$t=0$$,
  • $$g$$ acceleration due the gravity.
Let $$T$$ be the time when the projectile hits positive $$x$$-axis (i.e. the ground). Find the maximum horizontal displacement of the projectile and show that angle between initial velocity vector and velocity vector at time $$T$$ is $$\pi/2$$.
Mathematics news on Phys.org
$x_{max} = \dfrac{v_0^2}{g\tan{\alpha_0}}$
(bonus info that can be determined in working this problem) ... the value of $\alpha_0$ that yields a maximum horizontal range is $\alpha_0 = \arctan\left(\dfrac{v_0}{\sqrt{v_0^2 + 2gy_0}}\right)$
let $a = \alpha_0$, initial launch angle (too lazy to type out the Latex)
$b$ = final impact angle at time $T$$T=\dfrac{x}{v_0\cos{a}}$ substitute this expression for $T$ into the equation for $y$. Note $y(T)=0$
$0=y_0 + x\tan{a} - \dfrac{g}{2v_0^2} \cdot x^2\sec^2{a}$
derivative w/respect to $a$ ...
$0 = x\sec^2{a} + \tan{a} \cdot \dfrac{dx}{da} - \dfrac{g}{v_0^2} \left(x^2 \sec^2{a}\tan{a}+x\sec^2{a} \cdot \dfrac{dx}{da} \right)$
when $x$ is a maximum, $\dfrac{dx}{da} = 0$ ...
$0 = x\sec^2{a} - \dfrac{g}{v_0^2} \left(x^2 \sec^2{a}\tan{a}\right)$
$0 = x\sec^2{a}\bigg[1 - \dfrac{g}{v_0^2} \left(x \tan{a}\right) \bigg]$
$x\sec^2{a} \ne 0 \implies x = \dfrac{v_0^2}{g\tan{a}} \implies T = \dfrac{v_0}{g\sin{a}}$
$v_{fx} = v_0\cos{a}$
$v_{fy} = v_0\sin{a} - gT = -v_0 \cdot \dfrac{\cos^2{a}}{\sin{a}}$
$\tan{b} = \dfrac{v_{fy}}{v_{fx}} = -\cot{a}$
$\tan{b} \cdot \tan{a} = -\cot{a} \cdot \tan{a} = -1 \implies a \perp b$
Thank you for your solution! ^^
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
