C/C++ Max length of substring-palindrome
  • Thread starter Thread starter member 428835
    Length Max
The discussion focuses on finding the maximum length of a substring palindrome using a specific algorithm. The proposed logic involves using a for loop to iterate through the string with a left index (L) and a right index (R). The while loop is designed to compare characters from both ends, adjusting the indices based on matches and counting potential palindrome lengths. However, a critical bug is identified: the condition where L equals R is unreachable because the while loop terminates when L is no longer less than R. This oversight prevents the algorithm from correctly identifying odd-length palindromes. The code provided demonstrates the implementation but requires adjustments to address this issue for accurate palindrome length calculation.
member 428835
Hi PF!
I'm trying to find the max length of a sub-string palindrome. My logic is to have a left-most index called start that starts from string loc 0 and traverses to the end of the string via a for loop. Next I was thinking a while loop as long as L < R: I'd have a left index L=start and a right index R = string.length(). If ##L \neq R##, then ##R = R-1## and continue the while loop. However, if ##L = R## then ##L++## and ##R--##, we count this as a match, and continue. Only until L and R are the same (odd palindrome) or 1 away (even palindrome) do we replace the max palindrome length. However, I have a few bugs. Here's what I have, and any help is much appreciated.
C++:
#include <iostream>
#include <vector>
#include <string> // for string class
class Solution {
public:
    int longestPalindrome(std::string str) {
        int n = str.length();
        int maxLen = 1;
        int count = 0;
        for (int start = 0; start < n; start++) {
            int L = start;
            int R = n - 1;
            while (R > L) {
                if (str[R] != str[L]) {
                    R--;
                    continue;
                count ++;
                if (L == R) {
                    maxLen = std::max(maxLen, 2*count+1);
                    count = 0;
                    break;
                if (L == R - 1) {
                    maxLen = std::max(maxLen, 2*count);
                    count = 0;
                    break;
                L++;
                R--;
        return maxLen;
int main()
    std::string s_ = "yyureeeerl";
    Solution ob1;
    auto sol = ob1.longestPalindrome(s_);
    std::cout << sol << "\n";
    return 0;
Technology news on Phys.org
I didn't spend that much time on your code, but the one obvious problem I can see is that the if(L==R) block is unreachable because the while loop is over when that happens!
Likes member 428835
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
