MHB Max n for Sum of 3 Numbers Multiple of 27 in A
To determine the maximum number of elements \( n \) that can be selected from the set \( A = \{1, 2, 3, \ldots, 2015\} \) such that the sum of any three chosen numbers is a multiple of 27, it is essential to analyze the residues of the numbers modulo 27. The residues range from 0 to 26, and for the sum of any three residues to be a multiple of 27, they must be selected carefully to maintain this condition. The maximum \( n \) can be derived from the combinations of residues that satisfy the multiple of 27 requirement. The largest number that can be included in set \( B \) is also relevant in this context. The solution provides a systematic approach to finding both \( max(n) \) and the largest number in \( A \).
Albert1
$A=\begin{Bmatrix}
{1,2,3,4,5,------,2015}
\end{Bmatrix}$
if we pick $n$ numbers from $A$, we call it the set $B$ ,and the sum of any three numbers from $B$
are multiple of 27 ,find $max(n)$ , and the largest number we can choose from $A$
Mathematics news on Phys.org
Albert said:
$A=\begin{Bmatrix}
\end{Bmatrix}$
sum of any 3 divisible by 27. So the numbers have to be 0 mod 27 or 9 mod 27 or 18 mod 27. This is so because all 3 have to same mod 27.
$2015 = 27 * 74 + 17$ if we take $27k + 9$ then k goes from 0 to 74 that is n = 75
27 k means 74 numbers and 27k + 18 means 74
so $n = 75$
so $n = 75$
very good ! your answer is correct
$B=(9,36,63,------,2007)$
we have 75 elements in $B$
$max(n)=75$
and the largest number must be taken from $A$ is $2007$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
