MHB Max or Min curve on a graph question
  • Thread starter Thread starter ai93
    Curve Graph Max
The discussion focuses on solving the quadratic equation x² + 5x - 6, where the roots are found to be x = 6 and x = -1 using the quadratic formula. The graph of the function is sketched, indicating that it crosses the x-axis at -3 and 6, with a minimum point at (-2.5, -12.25). The derivative confirms the minimum value of the curve, as the second derivative is positive. The equation of the tangent line at x = 2 is discussed, with participants clarifying the formula needed and the values to substitute. Overall, the conversation emphasizes the importance of understanding the properties of quadratic functions and their graphical representations.
ai93
a) Find the roots of the equation $$x^{2}+5x-6$$
b) Sketch the graph of the function $$x^{2}+5x-6$$ labeling the points at which the graph crosses the axes and the co-ordinates of the maximum and minimum of the curve
c) Find the equation of the tangent at the point where $$x=2$$ on the curve of $$y=x^{2}+5x-6$$
MY SOLUTION Right so far?
a) Using the quadratic formula, we get $$x=\frac{-5\pm\sqrt{49}}{2}$$
$$\therefore x=6$$ or $$-1$$
b)
$$y=x^{2}+5x-6$$
$$\d{y}{x}$$ = $$2x+5$$
$$x=-\frac{5}{2}$$ (-2.5)
Sub x into equation
$$y=(-\frac{5}{2})^{2}+5(-\frac{5}{2})-6$$
y=$$-\frac{49}{4}$$ (-12.25)
and $$\d{y^{2}}{^{2}x}$$ = 2 which is a minimum value
So with the graph, you would plot it with the parabola going with the x points -3 and 6 and the y points $$-\frac{49}{4}$$
c) No clue!
Mathematics news on Phys.org
Note that this is not an equation because an equation must have the = sign. You could find the roots of the equation $$x^{2}+5x-6=0$$ or of polynomial $$x^{2}+5x-6$$.
I recommend substituting these values back into the original equation and checking if they are indeed roots.
mathsheadache said:
b)
$$y=x^{2}+5x-6$$
Sub x into equation
I agree. It may make sense to remember that the $x$-coordinate of the vertex of the parabola $y=ax^2+bx+c$ is $-b/(2a)$ and that the type of extremum is determined by the sign of $a$: if $a>0$, then the function has a minimum and if $a<0$, then it has a maximum.
This is stated a little vague.
The equation of the tangent to $y=f(x)$ at point $(x_0,f(x_0))$ is $y-y_0=f'(x_0)(x-x_0)$.
Is this the formula? What values would you need to sub in?
Well, it's not an apple! (Smile) You can see it in Wikipedia.
I think my post mentions everything that one needs to use this formula. I suggest you re-read it, and if you have further questions, feel free to describe what you don't understand.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
11K
