Max Principle: Showing $|u_1-u_2|\leq \max_{\partial{\Omega}}|g_1-g_2|$
In summary: Yup.Now we only need that $\max\limits_{x \in \partial{\Omega}} (-(g_1(x)-g_2(x))) \le \max\limits_{x \in \partial{\Omega}} |g_1(x)-g_2(x)|$... (Thinking)In summary, we use the maximum principle to show that $|u_1(x)-u_2(x)| \leq \max_{x \in \partial{\Omega}}|g_1(x)-g_2(x)|, x \in \Omega$ by considering cases where $u_1(y) - u_2(y) \geq 0$ and $u_1(y) -
mathmari
MHB
5,049
Hey! :eek:
Let $\Omega$ a bounded space. Let $u_1$ the solution of the problem $$-\Delta u_1(x)=f(x), x \in \Omega \\ u_1(x)=g_1(x), x \in \partial{\Omega}$$ and $u_2$ is the solution of the problem $$-\Delta u_2(x)=f(x), x \in \Omega \\ u_2(x)=g_2(x), x \in \partial{\Omega}$$ Using the maximum principle I have to show that $$|u_1(x)-u_2(x)| \leq \max_{x \in \partial{\Omega}}|g_1(x)-g_2(x)|, x \in \Omega$$
I have done the following:
Subtracting the two problems we get the following:
$$\Delta (u_1(x)-u_2(x))=0, x \in \Omega \\ u_1(x)-u_2(x)=g_1(x)-g_2(x), x \in \partial{\Omega} $$ and $$\Delta(-(u_1(x)-u_2(x)))=0, x\in \Omega \\ -(u_1(x)-u_2(x))=-(g_1(x)-g_2(x)), x \in \partial{\Omega}$$ Since $\Delta (u_1-u_2) \geq 0$, from the maximum for $u_1-u_2$ we have that $$\max_{\Omega}(u_1-u_2)=\max_{\partial{\Omega}}(u_1-u_2)=\max_{\partial{\Omega}}(g_1-g_2)$$ Since $\Delta (-(u_1-u_2)) \geq 0$, from the maximum for $-(u_1-u_2)$ we have that $$\max_{\Omega}(-(u_1-u_2))=\max_{\partial{\Omega}}(-(u_1-u_2))=\max_{\partial{\Omega}}(-(g_1-g_2))$$ Since $$\max (-(u_1-u_2))=\min (u_1-u_2)$$ we have that $$\min_{\Omega}(u_1-u_2) \leq u_1-u_2 \leq \max_{\Omega}(u_1-u_2) \\ \Rightarrow \max_{\partial{\Omega}}(-(g_1-g_2)) \leq u_1-u_2 \leq \max_{\partial{\Omega}}(g_1-g_2)$$
Is this correct so far?? How could we continue to show that $$|u_1(x)-u_2(x)| \leq \max_{x \in \partial{\Omega}}|g_1(x)-g_2(x)|, x \in \Omega$$ ?? (Wondering)
Hi! (Blush)
Looks good to me. (Nod)
Suppose we distinguish cases... (Thinking)
Suppose that at some point $y \in \Omega$ we have that $u_1(y) - u_2(y) \ge 0$.
Then:
$$|u_1(y) - u_2(y)| = u_1(y) - u_2(y) \le \max_{x \in \partial \Omega} (g_1(x)-g_2(x)) \le \max_{x \in \partial \Omega} |g_1(x)-g_2(x)|$$
Now suppose that $u_1(y) - u_2(y) < 0$... (Thinking)
(Happy)
Then:
When we have that $u_1(y)-u_2(y)<0$, then:
$$|u_1(y)-u_2(y)|=-(u_1(y)-u_2(y)) \leq \max_{x \in \Omega} (-(u_1(x)-u_2(x)))=\max_{x \in \partial{\Omega}} (-(g_1(x)-g_2(x)))$$
Is this correct so far?? (Wondering)
Yup.
FAQ: Max Principle: Showing $|u_1-u_2|\leq \max_{\partial{\Omega}}|g_1-g_2|$
What is the Max Principle?
The Max Principle is a theorem in mathematics that states that the maximum value of a function on the boundary of a region is equal to the maximum value of the function within the region.
How is the Max Principle used in this context?
In this context, the Max Principle is used to show that the difference between two solutions to a problem, represented by the functions u1 and u2, is less than or equal to the maximum difference between their boundary conditions, represented by the functions g1 and g2.
What is the significance of showing this inequality?
This inequality is significant because it allows us to compare the solutions to a problem and determine if they are close to each other. It also helps us understand the relationship between the solutions and their corresponding boundary conditions.
Can you provide an example of how the Max Principle is applied?
Sure, for example, let's say we have a heat transfer problem where the temperature u1 at the boundary of the region is known and the temperature u2 at the interior point is a function of the boundary temperature g1. The Max Principle can be used to show that the difference between u1 and u2 is less than or equal to the maximum difference between g1 and g2.
Are there any limitations to the Max Principle?
Yes, the Max Principle is limited to linear problems, where the boundary conditions and the solutions are linear functions. It also assumes that the boundary conditions are continuous, and the problem is well-posed.
