Max Speed to Move from Point A to Point B
In summary: You need to work out how long each part...Acceleration at aConstant velocityDeceleration at -awould take.
  • #36
CWatters said:
You seem to be making this problem much harder than it is. I very much doubt they intended you to think about limitations due to the speed of light!
It starts from A at rest and accelerates at "a". At some point it must stop accelerating and start to decelerate at "a" in order to be at rest at B.
A few basic equations of motion (eg SUVAT) and you are done.
I asked my teacher today. He said that indeed it start ar rest and accelerates at a and at somep point it decelerate at a in order to be at rest at B. He said that there arte two cases and that I need to choose one and explain why. So yes, I can use SUVAT equations. Which are the two cases?
  • #37
Pity that wasn't stated in the first place.
So turn that into some equations.
Unless there is also a max allowed speed, I can only think of one case.
  • #38
Not trying to be funny, but are you and the instructor both native speakers of the same language ?
The "two cases" are:
1) constant velocity gets there in the least amount of time
2) symmetrical acc/deceleration gets there in the least amount of time.
Pick one (or both) and state the condition - which includes the term "maximum velocity" - that makes it true.
  • #39
Given the clarification that it starts and finishes at rest, I don't see how that can be a sensible case.
Also, we've seen no mention of a maximum velocity, so dropping the start and finish at rest constraint for the constant speed case doesn't help.
If we were given a max speed the answer would depend on the relationship between that, the acceleration a and the distance.
This leaves the view that
- it starts and finishes at rest
- in between, any mix of accelerating at a, decelerating at a, and constant speed
But I count that as one case, not two.
  • #40
I think "choosing a case" means arbitrarily picking either "cv wins" or "acc/dec wins", then working backwards to state the condition(s) that makes it so.
  • #41
hmmm27 said:
I think choosing a "case" means arbitrarily picking either "cv wins" or "acc/dec wins", then working backwards to state the condition(s) that makes it so.
Effectively turning it into this model:
...maybe.
  • #42
Ok, can I use ##s=v_0 t+\frac{1}{2}at^2##? And it will end up being ##s=\frac{1}{2}at^2## since ##v_0=0##?
  • #43
Ok, but how are you using it, i.e. what is s here?
  • #44
Well, ##s## can't be ##L##, because it isn't accelerating all way through, it would be the distance before it starts desaccelerating. Whn it starts desaccelerating, it would be ##s=v_0 t-\frac{1}{2}at^2##, right?
  • #45
Yes.
  • #46
haruspex said:
Yes.
Ok. But what should I replace on the variables? Or should I just leave those two equations?
  • #47
No, you must answer using the given variables L and a.
Use your two equations to find out when you have to switch to decelerating.
  • #48
The only two cases I can think of are..
1) Accelerate, constant velocity, decelerate
2) Accelerate, decelerate with no constant velocity phase.
  • #49
But isn't the second just a special case of the first?
  • #50
Indeed. But it's the best I can come up with for "two cases".
  • #51
Thanks, I did it by saying that the max velocity is when the velocity is constant. I showed it with the SUVAT equations, hope it is right.
  • #52
That doesn't work if the question intends what I think it does, as laid out in post #39.
With no acceleration, it can never start to move.
  • #53
But if it first goes with a constant acceleratio, then has constant velocity and then desaccelerate with constant acceleration, wouln't it be the max speed when the speed is constant?
  • #54
Yes, but the task it minimise the total time of travel. How should you apportion the time to the three stages?
Likes CWatters
