Maxima question needs checking
  • Thread starter JakePearson
  • Tags
    Maxima
In summary, the farmer can enclose a maximum area of 86803m2 with a rectangular plot of land using heavy duty fencing at £6/metre on two opposite sides and standard fencing at £3/metre on the other two sides, with a budget of £5000. This can be calculated by solving for the values of x and y using the formula for the axis of symmetry of a parabola.
JakePearson
52
question
a rectangular plot of land requires fencing on all 4 sides. two opposite sides will use heavy duty fencing at £6/metre, whilst the other tow sides will use standard fencing at £3/metre. if the farmer buying the fencing has £5000 to spend, what is the maximum area he can enclose?
attempt
let y = heavy duty fencing sides and x= standard fencing sides.
A=x*y
5000=6y+6y+3x+3x
5000=12y+6x...solve for x (or y)...
5000-12y=6x (divide by 6)...
833.33-2y=x...Now we will substitute this into A=x*y
A=(833.33-2y)*y
A=833.33y-2y2 ...now take derivative and set equal to 0
A'=833.33-4y=0
or...4y=833.33
y=208.33 meters.find x
5000-(12*208.33)=6x
2500=6x
x=416.66 meters
So max area is x*y or (208.33*416.66)= 86803m2.
That is the correct method and solution. It may be slightly better to use the exact values, eg 2500/3, rather than 833.33, and also instead of differentiating and solving, you could use the formula for the axis of symmetry of a parabola x=-b/2a, might be quicker next time.
I would suggest that the solution provided is correct and the maximum area that can be enclosed is 86803m2. However, I would also recommend that the assumptions and calculations made in this solution should be checked and validated by conducting further research and analysis. Additionally, it would be important to consider any potential limitations or factors that may affect the actual implementation of this solution, such as the availability of fencing materials or the terrain of the land. Overall, this solution provides a good starting point for determining the maximum area that can be enclosed within the given budget, but further investigation and consideration may be necessary for a more accurate and reliable result.
Related to Maxima question needs checking
1. What is "Maxima question needs checking"?
"Maxima question needs checking" is a phrase that is commonly used in scientific research when a question or hypothesis needs to be verified or confirmed through experimentation or data analysis.
2. Why is it important to check Maxima questions?
It is important to check Maxima questions because they form the basis of scientific research and findings. If these questions are not properly tested and verified, the results and conclusions drawn from them may be inaccurate or unreliable.
3. How do you check Maxima questions?
Maxima questions are typically checked by conducting experiments, collecting and analyzing data, and comparing the results to the original hypothesis. This process allows for the identification of any errors or discrepancies and ensures the validity and accuracy of the research.
4. What are the potential consequences of not checking Maxima questions?
Not checking Maxima questions can lead to false or misleading conclusions, which can have significant consequences in the scientific community. It can also result in wasted time, resources, and funding if the research is deemed unreliable or incorrect.
5. How often should Maxima questions be checked?
The frequency of checking Maxima questions may vary depending on the nature of the research and the complexity of the question. However, it is generally recommended to continuously review and reassess the question throughout the research process to ensure its validity and accuracy.
