Maximazation of current in LC circuit
In summary, there is a discussion about the relationship between current and the discharge of a capacitor in an LC oscillator circuit. While the energy perspective explains why the current is maximized when the capacitor is fully discharged, there is a question about the dynamical approach and the role of electrons in this process. The equations for the circuit's behavior are provided, and the concept of electromagnetic induction is mentioned as a factor in the current's behavior. However, it is also noted that looking at the circuit from a microscopic level may not be the most efficient way to understand its behavior.
miko1977
Hello guys
This is my first post and i am glad to be a member of this forum. There is something bugging me for a lot of time. I have a problem understanding why the current of an LC oscilator circuit is maximized when the capacitor is fully discharged. Of course when it is explained from the energy perspective it makes sense since the energy of th circuit is transformed totally to magnetic energy. But what about the dynamical approach of the problem. Why the electrons drift velocity maximizes (and so the current) when the capacitor is discharged?
I know that when the switch is closed there are two electric fields in the conductors, the electric field due to the charged capacitor and the opposing induced electric field from the coil. What is the relationship between these fields? Which is bigger? I suppose the electric field of the capacitor, that is why the current increases. I am not sure. Please help!
Minas
Are you able to set up the equation:
[itex]-L\frac{dI}{dt}= \frac{Q}{C}[/itex] ?
Here, I is the current, which is the rate of increase of charge ±Q on the capacitor plates (that is the rate of transfer of charge through the inductor from the +plate of the capacitor to the - plate). So [itex]I=\frac{dQ}{dt}[/itex]
So [itex]-L\frac{d^{2}Q}{dt^2}= \frac{Q}{C}[/itex]
The general solution to this equation is [itex]Q=Q_0 sin(ωt + ε)[/itex]
in which [itex]ω^2=\frac{1}{LC}[/itex]
So [itex]I =Q_{0}ω cos(ωt + ε)[/itex]
Thanks for the reply Philip.
I am aware of the approach, you are essentially using the first Kirchoff rule which is based on thw conservation of the charge. I need an explanation of what happens dynamically. Why the electrons reach their maximum drift velocity when the capacitor is discharged?
Hallo Miko. I posted in error - the post wasn't complete. I was going to point out that we have a perfect electrical analogue to a mass-spring system doing SHM. The form of the equations is identical.
The displacement x (from equilibrium) in the mechanical system is analogous to the charge Q on one capacitor plate. When x is zero, the mass is in the middle of its swing, and dx/dt is at its greatest. When Q is zero (i.e the capacitor is discharged), dQ/dt (i.e. current) is at its greatest.
You can go a step further and regard the inductor as like the mass in the mechanical system, and the capacitor as like the spring. When Q = 0, the spring is neither stretched nor compressed, but the inductance (inertia) keeps the current flowing, so the capacitor starts charging in the other direction. Dropping the analogy, the inductor produces a back-emf which opposes change in current, so the current doesn't suddenly cease when the capacitor is empty.
Some of this is a bit hand-waving. Hope it helps.
Hey Philip
The analogy is always helpful and i am aware of it. But it doesn't give a realistic explanation of why the drift velocity of the electrons maximizes when the capacitor is discharged. I am still in dark.
Thanks anyway
\m/
miko1977 said:
Hey Philip
Thanks anyway
\m/
The drift velocity of the electrons has nothing (well, very little) to do with the amount of current flowing in a circuit. It is better to forget about electrons altogether when trying to understand what happens at the circuit level.
I'm sorry to have to say that the only response I can give (other than the mechanical analogy) is to refer you back to the equations I gave in my first post on this thread. Do you understand where they come from, i.e. the laws of electromagnetic induction, the concepts of emf, pd, inductance and capacitance? If you do understand, then you should see where the equations come from and how they lead inescapably to the current being a maximum when the charge on the capacitor is zero. If you don't understand, do say...
The drift velocity is, of course, proportional to the current. But if you're looking for an explanation in terms of free electrons, we can regard the emf induced in the inductor as work done per unit charge on the free electrons in the wire, which implies the existence of forces on them, due to an electric field arising – Faraday's Law - from the changing flux through the coil.
hi f9toli
I don't get it when you say that the current has nothing to do with the electrons drift velocity. From what i know it is proportional to the current. I know that viewing a circuit at a microscopic level (electrons) is not the most efficient way but then again it is something i need to clarify for personal reasons.
Minas
Yes Philip
I do understand your explanations very well and i know that the results are unquestionable. But i am taking this different microscopic approach on explaining what happens. It is something that i always try to do when dealing with a phenomenon. This bugs me for a lot of time! Maybe what i am searching is a "mechanical" explanation of what happens to the electrons in the conductors similar to what happens to a body attached on a spring.
What did you make of my second paragraph, where I talked about forces on free electrons in the conductor? Isn't that style of explanation along the lines you wanted? There are also Coulomb-type attraction and repulsion forces due to the charges on the capacitor plates. Consider both these forces, correlate them with the equations, and surely you've got what you wanted! If not, I'm baffled.
I suppose you might want a mechanical picture of what exerts these forces. In that case, you're back in the wonderful nineteenth century world of 'ethers' made of spinning vortices, and so on. Superseded for good reason, I'm afraid.
what you explained in your second paragrapgh (faradays law, induced electric field, work done on free electrons e.t.c) i have mentioned in my first post also. Which means that i am already aware of all that. You suggest me to consider both forces and correlate them. Well that is my question from the beginning (if you read carefully my first post). An analysis based on these forces that proves that the electrons are accelerating until the capacitor is fully discharged.
miko1977 said:
hi f9toli
Minas
This question comes up quite frequently and there is (unfortunately) no easy answer to what happens at the microscopic level, even the simplest explanation of what happens in a real material require a fair amount of quantum mechanics (and that does not include scattering etc).
Anyway, note that the average drift velocity in a given direction of electrons in a typical metal is only a few cm/s, whereas the speed of an electrical signal is equal to the speed of light in that metal (for e.g. copper about 0.8c). Hence, for a typical circuit (excluding things like ballistic transport, single electron pumps etc) the two are not directly related. Note also that electrical transport even for free electrons is a collective phenomenon, meaning you can't really think of current as (number of electrons)/s either (unless you are talking about something like a CRT).
Miko. Well that's certainly put me in my place.
I leave you with (1/C)vL[itex]\ddot{v}[/itex] = 0.
in which v is the drift velocity.
And this: Q/C and -LdI/dt are the line integrals along the wire of the Coulomb and Faraday E fields. Assume these fields act parallel to the wire and are the same in magnitude all the way along it. Hence you have the relative magnitudes of the two fields.
Now we are getting somewhere. Thanks allot man!
FAQ: Maximazation of current in LC circuit
1. What is an LC circuit?
An LC circuit is a type of electrical circuit that consists of an inductor (L) and a capacitor (C) connected in parallel. This circuit is also known as a tank circuit, resonant circuit, or tuned circuit.
2. How does an LC circuit work?
An LC circuit works by storing energy in the electric and magnetic fields of the inductor and capacitor. When the circuit is first energized, the capacitor begins to charge and the inductor builds up a magnetic field. As the capacitor becomes fully charged, the energy stored in the magnetic field of the inductor is released, causing the current to flow back and forth between the capacitor and inductor. This back-and-forth oscillation is what allows for the maximization of current in an LC circuit.
3. What is the maximum current in an LC circuit?
The maximum current in an LC circuit depends on the values of the inductance and capacitance, as well as the frequency of the input voltage. At resonance, when the frequency of the input voltage matches the natural frequency of the circuit, the maximum current will be at its peak value. This value can be calculated using the formula I = V/R, where V is the voltage and R is the total resistance of the circuit.
4. How can I maximize the current in an LC circuit?
To maximize the current in an LC circuit, you can adjust the inductance, capacitance, or frequency of the input voltage. Increasing the inductance or capacitance will lower the natural frequency of the circuit, while increasing the frequency of the input voltage will raise it. At resonance, when the natural frequency matches the input frequency, the current will be maximized.
5. What are some real-world applications of LC circuits?
LC circuits have many practical applications, including in radio and television broadcasting, where they are used to tune in to specific frequencies. They are also used in electronic filters, such as in audio equipment, to selectively pass or block certain frequencies. Additionally, LC circuits are used in electronic oscillators, such as in clocks and watches, to generate precise frequencies for timekeeping.
16K
