Maximization of an Uncertainty Product
In summary, the problem involves finding the linear combination of spin-up and spin-down S_z eigenkets that maximizes the uncertainty product \langle(\Delta S_x)^2\rangle\langle(\Delta S_y)^2\rangle. The solution involves using the normalized spin-space ket and the spin-1/2 representation, resulting in an uncertainty product function that is a function of two variables, \phi and \theta, which can be maximized. However, due to degenerate maxima at phi = nπ/2 for any theta, this may not be the expected answer for the problem.
Theage
[/B]
Sakurai problem 1.20: find the linear combination of spin-up and spin-down S_z eigenkets that maximizes the uncertainty product [itex]\langle(\Delta S_x)^2\rangle\langle(\Delta S_y)^2\rangle.[/itex]
[/B]
In general, we can write a normalized spin-space ket as [tex]\vert\alpha\rangle = \cos\phi\vert +\rangle+\sin\phi e^{i\theta}\vert -\rangle.[/tex] Various trig identities are probably relevant (sums and differences of similar complex exponentials and the like). Also, the spin-1/2 representation [itex]S_i = \frac\hbar 2\sigma_i[/itex] is certainly relevant.
[/B]
Since the Pauli sigma matrices are involuntary and the ket is normalized we see immediately that [tex]\langle S_x^2\rangle=\langle S_y^2\rangle =\frac{\hbar^2}4.[/tex] Using elementary trig we can also compute [tex]\langle S_x\rangle^2 = \hbar^2\sin^2\phi\cos^2\phi\cos^2\theta,\qquad\langle S_y\rangle = \hbar^2\sin^2\phi\cos^2\phi\sin^2\theta.[/tex] The uncertainty product is then a function F of two variables that should be maximized, and simplification yields [tex]F(\phi,\theta) = \hbar^4(\frac 1 4-\sin^2\phi\cos^2\phi\cos^2\theta)(\frac 1 4-\sin^2\phi\cos^2\phi\sin^2\theta) = \frac{\hbar^4}{16}(1-\sin^2(2\phi)+\frac 1 4\sin^4(2\phi)\sin^2(2\theta).[/tex] But this has degenerate maxima at phi = nπ/2 for any theta, which is definitely not the expected answer for the problem. Is this due to an algebraic mistake on my part or a conceptual mishap?
I think your answer is correct. Can you describe the physical interpretation of your angles ##\phi## and ##\theta## (or better, ##2\phi## and ##\theta## )? If so, your answer shouldn't be too surprising.
FAQ: Maximization of an Uncertainty Product
What is the "Maximization of an Uncertainty Product"?
The "Maximization of an Uncertainty Product" is a principle in physics that states that the product of the uncertainties in two conjugate variables, such as position and momentum, can never be smaller than a certain value. This value is known as the reduced Planck's constant, and is a fundamental limit to the precision with which these variables can be measured.
Why is the "Maximization of an Uncertainty Product" important?
The "Maximization of an Uncertainty Product" is important because it is a fundamental principle in quantum mechanics that governs the behavior of particles at the microscopic level. It helps to explain the uncertainty and randomness that is inherent in the behavior of particles, and has important implications for our understanding of the physical world.
How is the "Maximization of an Uncertainty Product" related to the Heisenberg uncertainty principle?
The "Maximization of an Uncertainty Product" is closely related to the Heisenberg uncertainty principle, which states that it is impossible to know both the position and momentum of a particle with absolute certainty. The principle of maximizing the uncertainty product is a mathematical consequence of the Heisenberg uncertainty principle.
Can the "Maximization of an Uncertainty Product" be violated?
No, the "Maximization of an Uncertainty Product" cannot be violated. It is a fundamental principle of quantum mechanics and is supported by experimental evidence. Any attempt to violate this principle would result in violating the Heisenberg uncertainty principle and would require a fundamental change in our understanding of the physical world.
How does the "Maximization of an Uncertainty Product" affect measurements in the real world?
The "Maximization of an Uncertainty Product" affects measurements in the real world by setting a limit to the precision with which certain conjugate variables can be simultaneously measured. This means that there will always be some uncertainty and randomness in the measurements, and this must be taken into account when interpreting experimental results. It also means that there is a fundamental limit to how precisely we can know certain properties of particles, which has implications for technologies such as quantum computing and cryptography.
