Maximizing Area for $6000: Fencing Solutions
  • MHB
  • Thread starter Yankel
  • Tags
    Area
In summary, we are looking to maximize the area of a rectangular region bounded by two types of fences, one costing \$60 per meter and the other costing \$50 per meter, with a total budget of \$6000. Using the constraint equation $6x+5y=300$, we can express the area as $A(x,y)=xy$, and then use single-variable calculus to find the value of $x$ that maximizes the function $A(x,y)$. The resulting optimal area is $750$ square meters.
Yankel
395
Hello
I could do with a hint or two for this one:
An squared area is to be bounded by using two types of fences. Two parallel flanks of the area will be bounded using a fence that cost \$60 per meter, while the other two will be bounded with a fence that cost \$50 per meter. What is the area with the maximal size which we can bound like this, so that our total expense will be \$6000 ?
Thanks !
The dollar sign character is used as a delimiter of LaTeX code, so if you wish to use this character to represent dollars, precede it with a backslash "\".
I'm assuming "squared area" means rectangular.
If we let x be the length of each parallel flank which costs \$60 per meter and y be the length of each parallel flank which costs \$50 per meter, then we require:
$2x(60)+2y(50)=6000$
Dividing through by 20, we obtain:
$6x+5y=300$
Now, what is the area, in terms of the two variable, that we wish to maximize?
the area should be x*y
so are you saying to write y as a function of x, and then use it in x*y, which will be a function of x too, which I will maximize ?
the final answer I got is 750, is it correct ?
Yes, that's right:
$\displaystyle A(x,y)=xy$
Now, you have three ways to proceed.
You may take the constraint, solve for one of the variables, then substitute for that variable into the objective function to get a quadratic objective function in one variable.
i) Pre-Calculus method
You may then choose to find the axis of symmetry which will give you the value of that variable which optimizes the objective function. Observing whether this parabola opens upwards or downwards will be enough to determine if the vertex is at a minimum or maximum. Then evaluate the objective function at the axis of symmetry to determine the optimal area.
ii) Single-variable calculus method
You may choose to differentiate the function, equate to zero to find the value of the variable which optimizes the objective function. Then you may use either the first or second derivative test to determine if you have a maximum or minimum. Then evaluate the objective function at this critical value to determine the optimal area.
iii) Multi-variable calculus method
You may also choose to use Lagrange multipliers to optimize the objective function using partial derivatives. This will tell you the relationship between the two variables, which you can then use in the constraint to determine the actual critical values, which you then use in the objective function to determine the optimal area.
I suspect you are to use the second option. (Smile)
You added this after I began to type my reply...
Yes, that's correct.
FAQ: Maximizing Area for $6000: Fencing Solutions
How much fencing is needed to maximize the area for $6000?
The amount of fencing needed to maximize the area for $6000 will depend on the cost per foot of fencing. If we assume a cost of $5 per foot, then we can purchase 1200 feet of fencing for $6000. This would allow us to enclose a maximum area of 1200 square feet.
What shape should the fencing be to maximize the area for $6000?
The shape of the fencing will depend on the desired dimensions of the enclosed area. Generally, a rectangular shape will provide the maximum area for a given perimeter. However, other factors such as land restrictions or aesthetic preferences may also play a role in determining the shape of the fencing.
Can different types of fencing be used to maximize the area for $6000?
Yes, different types of fencing can be used to maximize the area for $6000. However, the cost per foot of each type of fencing should be taken into consideration. For example, chain-link fencing may be less expensive than wood fencing, allowing for a larger area to be enclosed for the same budget.
Is it possible to maximize the area for $6000 with a limited amount of fencing materials?
Yes, it is possible to maximize the area for $6000 with a limited amount of fencing materials. This can be achieved by using fencing materials that are more cost-effective, such as chain-link fencing, and by selecting a shape for the fencing that allows for a larger area to be enclosed with less materials.
Are there any other factors to consider when maximizing the area for $6000 with fencing?
Yes, there are other factors to consider when maximizing the area for $6000 with fencing. These include the terrain of the land, any potential obstacles or obstructions that may affect the placement of the fencing, and any additional costs such as labor or permits. It is important to carefully plan and consider all of these factors in order to achieve the maximum area for the given budget.
