- #36
- 3,449
- 1,239
Andy Resnick said:I guess this is the source of my confusion: if there is a pressure loss associated with, for example, a sudden constriction, how is this manifested in the flow?
http://images.slideplayer.com/24/7380603/slides/slide_94.jpg
The figure above mentions that velocity increases but the kinetic energy decreases...??
A sudden constriction generally causes separation bubbles to form in the corners, and these recirculating regions lead to very high viscous dissipation. Physically, that is what is causing the extra head loss in a sudden contraction (or expansion, for that matter). The slide here is fairly vague in what they are describing as energy. They don't mean kinetic energy, as that is clearly increasing with the velocity increase. They are referencing the total available pool of energy available to the flow, e.g. the sum of kinetic energy, gravitational potential energy, and "pressure energy".
In the picture they drew, the height isn't changing so we can ignore gravity. If you ignore losses, the velocity increase predicted by conservation of mass would result in a pressure drop predicted by the Bernoulli equation. If you then include losses due to, for example, the contraction, the velocity change would be the same (conservation of mass still applies), but the pressure after the contraction would be lower than that predicted by Bernoulli alone. That is the nature of the equation I provided earlier. It basically says the sum of all of the forms of energy at point 1 equals the sum of all of those terms plus terms representing losses at point 2.
