Maximizing Momentum for a Rocket
In summary, the conversation discusses a problem with rockets losing momentum due to fuel jettisoning and the solutions proposed for finding the optimal time to stop ejecting fuel. The main question is whether leaving mass as a constant in the equations is a reasonable approach. Ultimately, it is determined that finding the maximum momentum with respect to velocity is the easiest method.
M-Speezy
The concept of a problem is that if rockets continue to jettison fuel, at some point they will get a very small momentum because their mas will be so small. (Bit of a silly problem, there's a lot of mass in the rocket itself) Anyways, the idea is that you would take the derivative of the momentum and find the time at which you should stop ejecting fuel. There are some solutions floating around, but they all say that momentum is m times the common velocity equation (exit velocity times the natural log of the ratio of initial mass to remaining mass). I said that mass was the (initial mass minus the rate of mass loss times time), which gives me a terrible derivative. The solutions I've seen just left mass as m. Is that a reasonable thing to do?
What you wrote above makes little to no sense to me. Try actually writing down the equations instead of describing them. That might help it make some sense.
Generally, we would say that the there's an equal and opposite force between ejected fuel and the momentary acceleration of a rocket. (This is how they accelerate in space)
Specifically, d(m)/dt*velocity of jettisoned gas = -m*dv/dt
This is rearranged so that it's integral (dm/m)=integral (dv) *1/v(exit). This gives the equation I initally spoke of, that the change of the velocity =V(exit)*Ln(M(initial)/M(final))
If it starts at rest, then that is the velocity.
Momentum is, of course, mass times velocity. The mass is dependent upon time, as it's ejected at some constant rate (we're assuming). Specifically, the mass at any time is M(initial)-d(m)/dt *T, or initial mass minus the rate of mass ejection times time. This expression for mass at some time ought to be substituted in for M(final) in the velocity I gave earlier.
This gives me, finally, momentum for some time: (M(initial)-dm/dt*T)*v(exit)ln(M(initial)/(M(initial)-dm/dt*T))
The derivative for this expression is pretty terrible. The other solution, which I have linked, just left m in its simplest form. My main question is if this is an appropriate thing to do, or not.
http://physics.oregonstate.edu/~jansenh/COURSES/ph435/Homework/Solution_4_3.pdf (The very first problem)
If you leave m as a constant then there will be no maximum. The rocket will continue to gain momentum as it burns fuel. So, given your desire to find the maximum momentum and given the fact that the simplification prevents exactly that then I think it is clear that you cannot use the simplification.
Nevermind, I realize now what this is. M is the variable that's being used. Rather than doing what I did, finding the specific time where it's maximized, it's easier to find the mass where it's maximized. At that point, it's trivial to find the time. Sorry, I should have been more observant of the solution I saw.
Thanks for the help!
Yes, I agree. It is definitely easier to find the maximum wrt mass than wrt time.
It's still easier to find the maximum wrt velocity. Once the speed of the rocket is bigger than the exhaust speed, the exhaust will also have momentum in the same direction as the rocket, so the rocket will lose momentum. While the velocity is still smaller than the exhaust speed, the exhaust will have momentum in the opposite direction, so the rocket will gain momentum. The maximum momentum is reached when the velocity of the rocket is equal to the exhaust speed.
The exhaust velocity is considered to be with respect to the rocket, and assumed constant. The faster the rocket, the higher the exhaust speed would be to a rest frame. Also, the derivative of velocity is the reason why it was an issue, because the velocity has such a complex relationship with both mass and therefore time. The problem is strange because of the added complexity that mass and time are related.
Related to Maximizing Momentum for a Rocket
1. How does the mass of a rocket affect its momentum?
The mass of a rocket directly affects its momentum. The greater the mass of a rocket, the greater its momentum will be. This is because momentum is defined as mass multiplied by velocity. Therefore, a rocket with a higher mass will have a higher momentum at the same velocity compared to a rocket with a lower mass.
2. How does the velocity of a rocket affect its momentum?
The velocity of a rocket also plays a significant role in its momentum. As mentioned before, momentum is equal to mass multiplied by velocity. This means that the higher the velocity of a rocket, the higher its momentum will be, regardless of its mass. In order to increase the momentum of a rocket, it is important to increase its velocity.
3. What is the relationship between thrust and momentum for a rocket?
Thrust is the force that propels a rocket forward. In order for a rocket to have momentum, it needs to have thrust. The greater the thrust of a rocket, the higher its momentum will be. This is because thrust is directly proportional to acceleration, and acceleration is a crucial factor in determining momentum.
4. How does the angle of launch affect a rocket's momentum?
The angle of launch can have a significant impact on a rocket's momentum. When a rocket is launched at a higher angle, it will have a greater horizontal velocity, resulting in a higher momentum. However, launching a rocket at too high of an angle can also cause it to veer off course, so finding the optimal angle for maximum momentum is important.
5. Can the shape of a rocket affect its momentum?
Yes, the shape of a rocket can affect its momentum. A streamlined and aerodynamic shape can reduce air resistance and increase the overall velocity of the rocket, resulting in a higher momentum. It is important for a rocket to be designed with the principles of aerodynamics in mind to maximize its momentum and efficiency.
  • Mechanics
