Maximizing Real Roots: Find Biggest Possible Value of a | POTW #199
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, maximizing real roots involves finding the largest possible value for a given equation, which can help us understand the behavior of systems and identify optimal conditions. This can be done using mathematical techniques such as differentiation and substitution. Real roots represent solutions that can be plotted on the real number line, while complex roots involve imaginary numbers and cannot be plotted. The biggest possible value of an equation can be negative, but when maximizing real roots, we are looking for the largest positive value. This concept has applications in various real-world scenarios, including production processes, system design, and predicting outcomes in economics and finance. It is also useful in fields such as physics and engineering to analyze physical systems.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $a,\,b,\,c,\,d$ be real numbers such that the equation $x^5-20x^4+ax^3+bx^2+cx+d=0$ has real roots only. Find the biggest possible value of $a$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to kaliprasad for his correct solution.:)
You can find the proposed solution below:
Let $f(x)=x^5-20x^4+ax^3+bx^2+cx+d$. If $f$ has all real roots, then the function of the third derivative of $f$ must have two real roots.
$f'(x)=5x^4-80x^3+3ax^2+2bx+c$
$f''(x)=20x^3-240x^2+6ax+2b$
$f'''(x)=60x^2-480x+6a$
If $f'''(x)=60x^2-480x+6a$ has two real roots, then its discriminant must be greater than or equal to zero:
$(-480)^2-4(60)(6a)\ge 0$
$a\le 160$
Therefore the biggest possible value of $a=160$.
FAQ: Maximizing Real Roots: Find Biggest Possible Value of a | POTW #199
What is the significance of maximizing real roots?
Maximizing real roots is a common problem in math and science that involves finding the largest possible value for a given equation. This can help us understand the behavior of a system or identify the optimal conditions for a particular outcome.
How do you find the biggest possible value of a given equation?
To find the biggest possible value of a given equation, we can use various mathematical techniques such as differentiation, substitution, and algebraic manipulation. These methods allow us to simplify the equation and identify the maximum value.
What is the difference between real roots and complex roots?
Real roots are solutions to an equation that can be represented on the real number line, while complex roots involve imaginary numbers and cannot be plotted on the real number line. In the context of maximizing real roots, we are only concerned with finding the highest real value.
Can the biggest possible value of a given equation be negative?
Yes, the biggest possible value of a given equation can be negative. This means that the equation has a minimum value rather than a maximum value. When maximizing real roots, we are looking for the largest positive value.
How can maximizing real roots be applied in real-world scenarios?
Maximizing real roots can be used in various real-world scenarios, such as optimizing production processes, designing efficient systems, and predicting outcomes in economics and finance. It can also be applied in fields such as physics and engineering to understand the behavior of physical systems.
