Maximizing Repulsive Force with an Electromagnet
In summary, a new forum member with little knowledge of electromagnets is seeking advice on how to use a rare Earth magnet with an electromagnet to create bursts of repelling force. They have a 2 1/2 inch round x 1 inch thick rare Earth magnet and a 12v car battery for their experiment, and access to soft iron of any size. They are unsure of the diameter and length of iron needed, the recommended gauge of magnet wire, and the number of turns needed for the electromagnet. They are also unsure of what amps would be best for their experiment. The expert advises being careful with the strong forces that can be generated and suggests constraining the permanent magnet or using active stabilization. They also recommend using magnet
Robertjpaul
Hi all.
New to the forum and new to making electromagnets. I want to pick your brains as I know extremely little about electromagnets.
So I have a 2 1/2 inch round x 1 inch thick rare Earth magnet that I’m trying to repel with force using an electro magnet. The repel would be in bursts. I know the rare Earth magnet is rated for around 400 pound lift. Also I’m using a 12v car battery for my experiment.
I have access to soft iron of any size.
My questions are.
What diameter and length iron would work best.
What gauge magnet wire do you recommend?
How many turns do you feel is needed for this magnet?
What amps would get me the most power or adequate power for my experiment?
I know nothing about any of this. I’ve tried searching but I keep finding equations I don’t understand.
Hmmm ... a little hard without equations, but also we would need a little more specification. Let’s see if I can say anything useful.
400 pounds is how much the magnet can lift when stuck directly to iron. The amount of force you can generate attracting or repelling it with an electromagnet is really only limited by how big of an electromagnet you can make and how strong of a (non magnetic) structure you can make to hold everything. It will be very easy to generate dangerous forces, so think hard about how strong everything is and whose fingers are in the way if things fail. Although not the most likely scenario, you could even launch the magnet at high speed, so be careful!
You didn’t say what you wanted to float or how high. I’ll assume you want to float the bare magnet and just high enough to see it is floating (1/4 inch?). The strength of your electromagnet isn’t going to be your problem. Your permanent magnet is very strong and you would have a hard time pushing it close to an opposed pole of a magnet of just about any strength. The trick is keeping it from flying/ falling off, or perhaps more likely, flipping over.
The simplest approach is to cheat, simply constrain the permanent magnet so it can’t do anything but move away. A close fitting see through tube would be one way.
Making it free float is much harder. It essentially can’t be done with just static magnets. You either need diamagnetic materials involved, or you need some sort of active stabilization.
To make a strong magnet, more windings in a smaller circle makes a stronger magnet. For this reason people invented magnet wire. Magnet wire is super small gauge and has a very thin varnish of insulation to allow as many wires as possible in the winding. You don’t need much insulation because the voltage is low. The limit is when the resistance of the wire creates enough heat in the winding to melt the wire. If don’t intend to control the current, you have to make the winding long enough so the resistance is high enough so the current is low enough that the wire doesn’t over heat. You mentioned you might be pulsing the current, so that can also keep the average power and heating down. Usually the design goes toward a gazillion windings of tiny wire, thus magnet wire.
Likes SergioPL
Yeah I guess I missed a few details. Sorry, I know they make all the difference.
So, yes the electromagnet will be held in place by a fixture. The permanent magnet will also be held but it will be allowed to move away from and back to the electromagnet. I plan to have a variable control for the power as to control it.
I want to see how fast I am able to repel the permanent magnet with as much strength as allowed without over powering the permanent magnet.
Thanks so much for the info though. It does help.
Thanks,
Rob
Related to Maximizing Repulsive Force with an Electromagnet
1. How does an electromagnet work?
An electromagnet works by using an electric current to generate a magnetic field. This is achieved by wrapping a wire around a ferromagnetic core, such as iron, and passing an electric current through the wire. The magnetic field created by the current aligns the magnetic domains in the core, creating a strong magnetic force.
2. How can I maximize the repulsive force of an electromagnet?
To maximize the repulsive force of an electromagnet, you can increase the number of turns in the wire, increase the current passing through the wire, or use a stronger ferromagnetic core. Additionally, you can adjust the distance between the electromagnet and the object it is repelling, as the force decreases with distance.
3. What factors affect the strength of an electromagnet?
The strength of an electromagnet is affected by the number of turns in the wire, the amount of current passing through the wire, the type of ferromagnetic core used, and the distance between the electromagnet and the object it is repelling. Other factors such as the diameter of the wire and the material of the wire can also have an impact on the strength of the electromagnet.
4. Can an electromagnet be used to attract objects?
Yes, an electromagnet can be used to attract objects by reversing the direction of the current passing through the wire. This will reverse the polarity of the magnetic field, causing the electromagnet to attract ferromagnetic objects instead of repelling them.
5. Are there any safety precautions to consider when working with electromagnets?
Yes, there are some safety precautions to consider when working with electromagnets. It is important to use caution when handling strong electromagnets, as they can attract or repel objects with great force. Additionally, make sure to use appropriate insulation for the wire and to avoid overheating the electromagnet, as this can cause damage to the wire or core.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
9K
  • Electromagnetism
