I Maximizing S/N in Angular Power Spectrum Signals
The discussion focuses on maximizing the signal-to-noise ratio (S/N) for angular power spectrum signals, specifically examining the impact of binning the power spectrum. Binning can theoretically reduce noise (Nl) by a factor of 1/sqrt(Δl), but concerns arise about whether summing over binned multipoles yields a cumulative S/N that is actually improved. The confusion lies in the summation term (2l + 1), which accounts for averaging over m modes within a multipole, despite Cℓ being constant for each m mode due to statistical isotropy. It is noted that random noise introduces a bias in Nℓ, complicating the benefits of binning. Ultimately, while binning may not directly enhance S/N, it can help mitigate variance across multipoles in actual measurements.
SherLOCKed
The signal-to-noise ratio for angular power spectrum signal Cl under theoretical noise Nl, where Cl and Nl are functions of multipole l, is given as
(S/N)^2= \sum (2l+1) (Cl/Nl)^2To increase the S/N we bin the power spectrum signal, if bin width \Delta l, this in principle decreases Nl by a factor of 1/sqrt(\Delta l).
Now, in (S/N)^2 should we replace the sum over multipoles with the sum over bin centers?
Space news on Phys.org
Thanks for the response. I checked the paper, it talks about the power spectrum binning. Suppose I bin the power spectrum as described in the paper.
The confusion I had is, if I just sum over the binned multipoles, I will end with the similar cummulative signal-to-noise ratio as before I started binning. So, binning is not necessarily helping to increase the signal-to-noise ratio.
@SherLOCKed I guess one thing that confuses me is why there is a summation over 2 + 1 in this case. That would make sense whenever averaging over all the m modes within a given multipole ℓ. But C is the same for every m mode at a given by assumption of statistical isotropy. So summing over m modes doesn't make sense to me. What does the summation do, and why isn't S/N just quantified as C/N at every multipole?
I agree that because we're considering power, not just amplitude, random noise produces an N that enters your spectrum as a bias, not just as variance. You can't get rid of it by binning multipoles. But for any actual measurement, the noise also causes multipole-to-multipole variance in the estimation of C that would average down through binning.
what is the current status of the field for quantum cosmology, are there any observations that support any theory of quantum cosmology? is it just cosmology during the Planck era or does it extend past the Planck era. what are the leading candidates into research into quantum cosmology and which physics departments research it? how much respect does loop quantum cosmology has compared to string cosmology with actual cosmologists?
