Maximizing the surface of a cylinder and a box
In summary, the post office has established that the length and the outline of any parcel may exceed the 100 cm. under such restriction. The dimensions for a circular cylinder straight greater possible surface are R= 50/(2pi-1), H= 100(pi-1)/(2pi-1), and a= 2piRH+ 2pi R^2. The dimensions for a rectangular box of square base of greater surface area are Lado 100/7, Length 300/7, width L, and height H.
leprofece
241
¿The post office has established that the length and the outline of any parcel may exceed the 100 cm. under such restriction find the dimensions for:
299) circular cylinder straight greater possible surface.
Answer R = 50/(2pi-1) H= 100(pi-1)/(2pi-1)
301) rectangular box of square base of greater surface area.
Answer Length 300/7
width Lado 100/7
There are this formula in my book
299) a = 2piRH
H = 100 -2piR
But I don't get the book answer R = 25/pi
301) H = 100 -2piR
and a = 2pirh +2pir2
re: Max and min 299 y 301
Do you mean that the length and outline of the parcel may NOT exceed 100cm?
prove it said:
do you mean that the length and outline of the parcel may not exceed 100cm?
yeah
Answer Length 300/7
width Lado 100/7
299) a = 2piRH
H = 100 -2piR
That "a" is for the curved surface. The total surface area includes the two circular ends: A= 2pi RH+ 2pi R^2. Replacing H with 100- 2pi R,
A= 2pi R(100- 2piR)+ 2pi R^2= 200pi R- 4pi^2R^2+ 2piR^2= 200pi R- (4pi^2- 2pi)R^2.
You don't say how you are to find the maximum area. Completing the square would work but be tedious. Taking the derivative and setting it equal to 0 give 200pi - (8pi^2- 4pi)R= 0, R= (200pi)/(8pi^2- 4p)= 25/(pi- 1)
301) H = 100 -2piR
? 301 was about a rectangular box. Where did "pi" come from? If a box has length L, width W, and height H, then its surface area is A= 2LW+ 2LH+ 2WH. The condition that "total outline plus length be no more than 100" gives 2W+ 2H+ L= 100 at most.
You don't say how you are to find the maximum area. Completing the square would work but be tedious. Taking the derivative and setting it equal to 0 give 200pi - (8pi^2- 4pi)R= 0, R= (200pi)/(8pi^2- 4p)= 25/(pi- 1)? 301 was about a rectangular box. Where did "pi" come from? If a box has length L, width W, and height H, then its surface area is A= 2LW+ 2LH+ 2WH. The condition that "total outline plus length be no more than 100" gives 2W+ 2H+ L= 100 at most.
Ok I solved 299
but in 301 it is a rectangular box whose bass is a square so L = w = y h
the other equation must be 2L2+4LH
let see if i got the answer 2w+2h+L = 100
si l = w I got 3l + 2h = 100
100- 3L /2 = H
No I got 5
Re: Max and min 299 y 301
Am I right or not?
Who has the reason? me orb the book?
FAQ: Maximizing the surface of a cylinder and a box
What is the formula for finding the surface area of a cylinder?
The formula for finding the surface area of a cylinder is 2πr² + 2πrh, where r is the radius and h is the height of the cylinder.
How can I maximize the surface area of a cylinder?
To maximize the surface area of a cylinder, you would need to increase either the radius or the height of the cylinder, or both. This would result in a larger surface area than a cylinder with smaller dimensions.
What is the formula for finding the surface area of a box?
The formula for finding the surface area of a box is 2(lw + lh + wh), where l is the length, w is the width, and h is the height of the box.
Can the surface area of a box be greater than that of a cylinder?
Yes, the surface area of a box can be greater than that of a cylinder if the dimensions of the box are larger than the dimensions of the cylinder.
How can I maximize the surface area of a box?
To maximize the surface area of a box, you would need to increase either the length, width, or height of the box, or a combination of these dimensions. This would result in a larger surface area than a box with smaller dimensions.
