Maximizing the volume of a cone formed by cutting a sector from a circle
In summary: Which is equal to:V=\frac{R^3}{24\pi^2}\beta^4\sqrt{16\pi^2-\beta^4}Which is equal to:V=\frac{R^3}{24\pi^2}\beta^8\sqrt{64\pi^2-\beta^8}
leprofece
241
From A circular sheet of RADIUS "R" a sector tie is cuts so that the coil Gets a funnel. Calculate the angle of the circular sector to cut back so of funnel has the maximum capacity. Answer tha angle is 2sqrt(6)pi/3
Re: Max and min two
You really should be posting what you have tried so far, but I will get you started.
We are going to take a circular sheet of radius $R$, and remove from it a circular sector whose central angle is $\theta$, leaving a circular sector from which we are going to form a cone. The radius of this cone can be found by using the formula for the length of a circular arc:
\(\displaystyle r=R(2\pi-\theta)\)
To determine the height of the cone, we may observe that the area of the sector from which we are forming the cone is equal to the lateral surface area of the cone:
\(\displaystyle \pi r\sqrt{r^2+h^2}=\frac{1}{2}R^2(2\pi-\theta)\)
Solve this for $h$, and then state your objective function, which is the volume of the cone:
\(\displaystyle V=\frac{1}{3}\pi r^2h\)
Substitute into this the values for $h$ and $r$ so that you have a function of the variable $\theta$ and the constant $R$, and then maximize.
Re: Max and min two
I wanted to repost as I originally made some errors which I want to correct.
We have:
\(\displaystyle r=\frac{R}{2\pi}(2\pi-\theta)\)
\(\displaystyle \pi r\sqrt{r^2+h^2}=\frac{1}{2}R^2(2\pi-\theta)=\pi rR\)
And so dividing through by $\pi r\ne0$ we obtain:
\(\displaystyle \sqrt{r^2+h^2}=R\)
Note: we could have more easily obtained this by simply analyzing the cross-section, but as they say hindsight is 20/20. :D
Squaring, we have:
\(\displaystyle r^2+h^2=R^2\)
Hence, isolating $h^2$ and substituting for $r$, we have:
\(\displaystyle h^2=R^2-\left(\frac{R}{2\pi}(2\pi-\theta) \right)^2=\left(\frac{R}{2\pi} \right)^2\theta(4\pi-\theta)\)
Taking the positive root, we obtain:
\(\displaystyle h=\frac{R}{2\pi}\sqrt{\theta(4\pi-\theta)}\)
And so now, the volume of the cone may be written as:
\(\displaystyle V=\frac{1}{3}\pi\left(\frac{R}{2\pi}(2\pi-\theta) \right)^2\left(\frac{R}{2\pi}\sqrt{\theta(4\pi-\theta)} \right)\)
\(\displaystyle V=\frac{R^3}{24\pi^2}(2\pi-\theta)^2\sqrt{\theta(4\pi-\theta)}\)
This is what you want to maximize, and after having worked out the problem, and looking at the answer you posted, the angle you are after is actually:
\(\displaystyle \beta=2\pi-\theta\)
So, in this case, you want to maximize:
\(\displaystyle V=\frac{R^3}{24\pi^2}\beta^2\sqrt{4\pi^2-\beta^2}\)
FAQ: Maximizing the volume of a cone formed by cutting a sector from a circle
How do you find the maximum volume of a cone formed by cutting a sector from a circle?
The maximum volume of a cone formed by cutting a sector from a circle can be found by using the formula V = (1/3)πr2h, where r is the radius of the circle and h is the height of the cone. This means that the maximum volume will be achieved when the radius and height of the cone are at their largest possible values.
What is the relationship between the radius and height of the cone and the maximum volume?
The radius and height of the cone are directly proportional to the maximum volume. This means that as the radius and height increase, the maximum volume also increases.
Can the maximum volume of a cone formed by cutting a sector from a circle be greater than the volume of the original cone?
No, the maximum volume of the cone formed by cutting a sector from a circle can never be greater than the volume of the original cone. This is because cutting a sector from the circle will always result in a smaller base and therefore a smaller volume.
How does the angle of the sector being cut affect the maximum volume of the cone?
The angle of the sector being cut has a significant impact on the maximum volume of the cone. The larger the angle, the larger the base of the cone and therefore the larger the volume. However, as the angle approaches 360 degrees, the cone becomes a full circle and the volume becomes equal to the original circle's volume.
What is the significance of maximizing the volume of a cone formed by cutting a sector from a circle?
Maximizing the volume of a cone formed by cutting a sector from a circle is important in many real-life applications, such as finding the maximum capacity of a container or optimizing the design of a cone-shaped structure. It also allows for efficient use of materials and resources.
