Maximizing the volume of a cylindrical postal package
In summary, the conversation discusses finding the maximum volume of a cylindrical postal package with a given sum of length and perimeter of its base. By setting up constraints and an objective function, the maximum volume is found to be 2547 cm3.
leprofece
241
The sum of the length and the perimeter of base of a postal package to is 60 cm. find the maximum volume:
when the package is cylindrical.
The answer is 2547 cm3
V cilinder = pir2h
and the sum L + L+H = 60
2L + H = 60
solving for H and putting it into the volume i don't get the answer
Yeah I got by h = 60-2L
Re: max and min 297
Let's let $P$ be the sum of the length and the perimeter of the base. For a cylinder, we then have the constraint:
\(\displaystyle 2\pi r+h=P\)
Now, the volume of the cylinder, our objective function, is:
\(\displaystyle V(r,h)=\pi r^2h\)
Solve the constraint for $h$, then substitute into the objective function for $h$, and you will then have a function in one variable, $r$. At this point you can maximize the function. You should show that the critical value is at a maximum. You should be able to show that:
\(\displaystyle V_{\max}=\frac{P^3}{27\pi}\)
Can you demonstrate that this is true?
Re: max and min 297
my solving is
pir2(60-2pir)
v= 60pir2-2pi2r2
V
dv = 120 pir -6pi2r
solving r= 20/pi
and h = 20
v= 8000/pi
Then v = 2547 cm3
Re: max and min 297
leprofece said:
my solving is
pir2(60-2pir)
v= 60pir2-2pi2r2
V
dv = 120 pir -6pi2r
solving r= 20/pi
and h = 20
v= 8000/pi
Then v = 2547 cm3
Yes, 8000/pi is the exact answer. (Yes)
FAQ: Maximizing the volume of a cylindrical postal package
How do I calculate the volume of a cylindrical postal package?
To calculate the volume of a cylindrical postal package, use the formula V = πr2h, where V is the volume, π is a constant (approximately 3.14), r is the radius of the cylinder, and h is the height of the cylinder.
What is the maximum volume for a cylindrical postal package?
The maximum volume for a cylindrical postal package will depend on the dimensions allowed by the postal service. It is important to check the size restrictions before attempting to maximize the volume.
How can I increase the volume of my cylindrical postal package?
To increase the volume of a cylindrical postal package, you can either increase the height or the radius of the cylinder. However, it is important to stay within the size restrictions set by the postal service.
Can the shape of the postal package affect the volume?
Yes, the shape of the postal package can affect the volume. A cylindrical shape has a smaller surface area compared to other shapes, allowing for a larger volume within the same size restrictions.
Is there a specific ratio of height to radius that maximizes the volume of a cylindrical postal package?
No, there is no specific ratio that maximizes the volume of a cylindrical postal package. It is important to experiment with different dimensions to find the best combination that stays within the size restrictions and maximizes the volume.
