Maximizing volume of a Square-Based Pyramid?
In summary, Sydney tried to solve an optimization problem involving a slant length and a height length, but she did not know how to get the derivative. After some research, she found that she needed to square root everything in order to get the derivative, and then use that to find the function in terms of x.
sidnygte
I am given an 8in x 8 in piece of paper and I need to build a pyramid with a square base with the greatest volume.
V = 1/3 * x^2 * h
b = base length
h = height length
I'm trying to get everything in terms of x, which is the length of the base of the square I need to make.
The slant length is l
w(length of the entire slant) = 2l + xhttp://i39.tinypic.com/2me4jsw.jpg
Oh and l = h^2 + x^2/2. height squared + one half x^2.
This is an optimization problem, so I put everything in terms of one variable, and then get the derivative
I just don't know if this is the derivative.
http://i44.tinypic.com/2rh07f5.jpg
Hi Sydneygte,
You made a little mistake: It should be (x/2)^2 instead of x^2/2.
Also, type in the expression of the volume in terms of x and its derivative. You picture is not clear.
ehild
ohh that changes it a bit
so h^2 = l^2 - (x/2)^2
so you can square root everything so
h = l - (x/2)? that doesn't seem right
If square roots worked like that, Pythagoras would have been out of business long ago.
Square roots don't work like that.
After all,
9 = 25 - 16 .​
But:
3 ≠ 5 - 4 .​
so what would the equation look like if you were trying to get H to the power of one?
h = sqrt(l^2 - .5x^2)?
It would be:
h = sqrt( l2 - (0.5x)2 )
or equivalently
h = sqrt( l2 - (0.25)x2 )
(That is a lower case L, not a number 1.)
so then the function in terms of x would be
V = 1/3X^2 * sqrt( sqrt(128)-x)^2 - (0.5x)^2) ?
that seems confusing haha. has would I simplify the double square root? Since it is being squared in the inside can I make it into
V = 1/3X^2 * sqrt(128 - X^2 - 0.25X^2)?
You can't do that either .
(a-b)2 a2 - b2 .
But the following is true:
(a-b)2 = a2 -2ab + b2
You will still have a square root if you "FOIL" ( sqrt(128)-x)2.
BTW, √(128) = (8)√(2), and either way you write this, it's just a number, there's no variable involved.
Also , you are missing a parenthesis in " sqrt( sqrt(128)-x)^2 - (0.5x)^2) ".
It should be: sqrt( ( sqrt(128)-x)^2 - (0.5x)^2) .
FAQ: Maximizing volume of a Square-Based Pyramid?
1. What is the formula for finding the volume of a square-based pyramid?
The formula for finding the volume of a square-based pyramid is V = (1/3) * b^2 * h, where b is the length of the base and h is the height of the pyramid.
2. How do you maximize the volume of a square-based pyramid?
To maximize the volume of a square-based pyramid, the base should have equal sides and the height should be as tall as possible without exceeding the length of the base. This will create a symmetrical pyramid with a larger base and height, resulting in a larger volume.
3. Can the volume of a square-based pyramid be negative?
No, the volume of a square-based pyramid cannot be negative. Volume is a measure of space and cannot have a negative value.
4. How does the volume of a square-based pyramid compare to the volume of a cube?
The volume of a square-based pyramid is always smaller than the volume of a cube with the same side length. This is because the pyramid has a slanted side, which takes up less space than the vertical sides of a cube.
5. Does the material used to construct a square-based pyramid affect its volume?
No, the material used to construct a square-based pyramid does not affect its volume. The volume is solely determined by the dimensions of the pyramid's base and height, not the material it is made of.
10K
14K
