Maximizing volume of cone inscribed within cone
In summary, the problem asks for the ratio of the heights of two right circular cones, with the smaller one inscribed inside the larger one and touching its center, that maximizes the volume of the smaller cone. By expressing the radius of the smaller cone as a function of its height, we can write the volume of the smaller cone and find its critical values using the first derivative test. The maximum volume occurs when the height of the smaller cone is one-third of the height of the larger cone.
nina94
A right circular cone is inscribed inside a larger right circular cone with a volume of 150 cm3. The axes of the cones coincide and the vertex of the inner cones touches the center of the base of the outer cone. Find the ratio of the heights of the cones that maximizes the volume of the inner cone.
So I know the figure looks like this, but I'm just not sure where to go from there. Help will be gladly appreciated.
Re: Calc word problem.
My approach here would be to observe that we need two things to compute the volume of the inner (smaller) cone...its base radius $r_S$ and height $h_S$. Now, we can let the height of the inner cone vary anywhere from $0$ to the height $h_L$ of the outer (larger) cone...and we can see that the radius of the inner cone will decrease linearly as its height increases. We know then if we write $r_S$ as a function of $h_S$, we will have the following point on the line:
\(\displaystyle (0,r_L),\,(h_L,0)\)
We now have two points on the line, so we can find the equation of the line...can you now express the radius of the inner cone as a function of the height of the inner cone?
\(\displaystyle r_S(h_S)=?\)
After 24 hours, let's wrap this up...we may write:
\(\displaystyle r_S(h_S)=-\frac{r_L}{h_L}h_S+r_L=r_L\left(1-\frac{h_S}{h_L}\right)\)
Now, since we are asked for the ratio of the heights of the two cones where the volume of the inner cone is maximized, let's call this ratio \(\displaystyle r=\frac{h_S}{h_L}\), and express the volume of the inner cone as:
\(\displaystyle V_S=\frac{\pi h_Lr_L^2}{3}r(1-r)^2\)
We need only maximize the non-constant portion of the volume, so let's write:
\(\displaystyle f(r)=r(1-r)^2\)
And we then find by equating the derivative to zero:
\(\displaystyle f'(r)=r(2(1-r)(-1))+1(1-r)^2=(1-r)(1-r-2r)=(1-r)(1-3r)\)
Thus, our critical values are:
\(\displaystyle r=\frac{1}{3},\,1\)
We see that on the interval \(\displaystyle \left(0,\frac{1}{3}\right)\), $f'$ is positive and on the interval \(\displaystyle \left(\frac{1}{3},1\right)\), $f'$ is negative, so by the first derivative test, we know:
\(\displaystyle f_{\max}=f\left(\frac{1}{3}\right)\)
From this we may conclude that the inner cone's volume is maximized when its height is one-third that of the outer cone.
FAQ: Maximizing volume of cone inscribed within cone
What is the formula for finding the maximum volume of a cone inscribed within another cone?
The formula for finding the maximum volume of a cone inscribed within another cone is V = (1/3)πr2h, where r is the radius of the base of the smaller cone and h is the height of the smaller cone.
How do you determine the optimal dimensions for the smaller cone to maximize volume?
The optimal dimensions for the smaller cone can be determined by using the derivative of the volume formula and setting it equal to zero. This will give you the critical radius and height values that will maximize the volume.
Is the maximum volume of the smaller cone always located at the center of the larger cone?
No, the maximum volume of the smaller cone can be located at any point on the base of the larger cone. It is not always located at the center.
Can the maximum volume of the smaller cone be greater than the volume of the larger cone?
No, the maximum volume of the smaller cone cannot be greater than the volume of the larger cone. The smaller cone is inscribed within the larger cone, so its volume will always be smaller.
What are some real-world applications of maximizing the volume of a cone inscribed within another cone?
One real-world application is in the design of ice cream cones. By maximizing the volume of the smaller cone, you can create a cone with a larger capacity for ice cream. This can also be applied in the design of storage containers to maximize the space inside. It is also important in engineering and architecture for optimizing the use of materials in structures such as bridges and towers.
