I Maximum acceleration of an alpha particle?
The discussion centers on estimating the maximum acceleration of an alpha particle during Rutherford backscattering, assuming elastic collisions. The kinetic energy of the alpha particle is equated to the electrostatic potential energy to find the closest distance to the nucleus, leading to a calculated acceleration of approximately 3 x 10^27 m/s² for a 5.4 MeV alpha particle. The conversation also explores the implications of quantum mechanics, particularly the de Broglie wavelength, suggesting that the concept of acceleration may not apply until a certain distance is reached. The participant seeks to understand the transition from wave-like behavior to particle-like behavior in this context. Overall, the discussion highlights the complexities of estimating maximum acceleration in quantum mechanical terms while addressing practical implications of alpha particle behavior.
Orthoceras
TL;DR Summary
Maximum acceleration of an alpha particle that is backscattered by a heavy atom?
I would like to estimate the maximum acceleration (or deceleration) of an alpha particle that is backscattered by a heavy atom, like in Rutherford backscattering. I am interested in the order of magnitude, not in a precise value. I am assuming the collision is elastic.
The kinetic energy of the free alpha particle is E. The closest distance of the alpha particle to the atom's nucleus, r_0, is found by equating E to the electrostatic potential energy: E = \frac{f q Q}{r_0} \Rightarrow r_0 = \frac{f q Q}{E}
The acceleration (or deceleration) at r = r_0, due to the repulsive Coulomb force, is: a_0 = \frac{F}{m} = \frac{f q Q}{{r_0}^2 m} = \frac{f q Q}{\left(\frac{f q Q}{E}\right)^2 m} = \frac{E^2}{f q Q m}
For example, if the alpha particle was generated by the decay of Po-210, with E=5.4 MeV, and the scattering nucleus is heavy compared to the alpha particle (for example, another polonium atom) then r_0 = 4⋅10^{-14} m and a_0 = 3⋅10^{27} \frac{m}{s^2}
However, I suppose a quantum mechanical wave does not have an acceleration, so r should be at least 10 times the de Broglie wavelength (assuming the de Broglie wavelength of a particle indicates the length scale at which wave-like properties are important for that particle). I tried a few r values and found that r=10 \lambda_{Broglie} at r=1.7 r_0. Then the acceleration is a = 1⋅10^{27} \frac{m}{s^2}. That is my estimate for the order of magnitude of the maximum acceleration of this 5.4 MeV alpha particle.
Is this a somewhat valid estimate?
An edit of that paragraph, to provide more clarity and correct a mistake:
However, the speed is zero at r=r_0, so the de Broglie wavelength is infinite, the alpha particle is a quantum mechanical wave, and I suppose a wave does not have an acceleration. Assuming the de Broglie wavelength of a particle indicates the length scale at which wave-like properties are important for that particle, r should be at least 10 times the de Broglie wavelength. The de Broglie wavelength is \lambda=\frac{h}{p} and p=\sqrt{2 m (E-\frac{kqQ}{r})}. Then r\approx 10\, \lambda at r=2 r_0, and the acceleration is a = \left(\frac{r0}{r}\right)^2a_0 = 0.7⋅10^{27} \frac{m}{s^2}. That is my estimate for the order of magnitude of the maximum acceleration of this 5.4 MeV alpha particle.
You are looking for an order of magnitude estimate. I don't understand why you are not content with the particle formulation of the answer. Why bother with the wave formulation in which you know that "maximum acceleration" is an ill-defined concept?
I bother with the wave formulation because of the next question. I was actually curious about the highest acceleration of objects present in our environment. The average human body contains 0.1 femtogram op Po-210, with an activity of 20 Bq, so many 5.4 MeV alpha particles are produced all the time inside us. The calculation of the maximum acceleration is the same as the one I used for Rutherford backscattering.
In this new case the wave is the initial form of the alpha particle, so it can't be ignored. My question is, at which distance do they transform from wave to particle, so at which distance is the concept of acceleration applicable? Would that be when r\approx 10\, \lambda, or at its first recoil action on the nucleus, or at its first interaction with an electron of the atom?
Even though an exact "maximum acceleration" is an ill-defined concept, I would expect that it should somehow be possible to estimate the order of magnitude.
Why are you considering alphas and not betas?
In alpha decay, the initial speed of the particle is known, it is zero. In beta decay, the initial speed is unknown. As a result I was able to calculate the initial acceleration of the particle in alpha decay, but not in beta decay..
Also, Rutherford has shown that an alpha particle is able to penetrate the atom as a projectile. An electron that penetrates an atom is less simple.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
