MHB Maximum and minimum of a function
anemone
MHB
POTW Director
Let $a$ be an integer. Consider the function $y=\dfrac{12x^2-12ax}{x^2+36}$. For what integral values of $a$ the maximum and the minimum of the function $y=f(x)$ are integers?
Mathematics news on Phys.org
We have $(y-12)x^2+12ax+36y=0$.
This quadratic equation in $x$ has a solution in real numbers if and only if the discriminant $D=12^2a^2-4\cdot 36y(y-12)=12^2(a^2-y^2+12y)\ge 0$.
This happens if and only if $y^2-12y-a^2\le 0$ and this holds if and only if
$6-\sqrt{36+a^2}\le y\le 6+\sqrt{36+a^2}$
The end points of the above interval are the minimum and maximum of $y$. If we want them to be integers then $36+a^2=b^2$ must be a perfect square. This gives $36=(b+a)(b-a)$. If we take $36=mn$ as any factorization of 36 into positive integers, then $a=\dfrac{m-n}{2}$ and $b=\dfrac{m+n}{2}$. Now, $a,\,b$ are integers implies that $m,\,n$ are both odd or they are even. This gives two possibilities
$36=6\times 6$ or $36=2\times 18$
Now, $m=6=n$ gives $a=0$ and this forces $x^2=-\dfrac{36}{y-12}$ and this has a solution if and only if $0\le y \le 12$. As we are interested in the maximum and minimum $a\ne 0$ and we have the corresponding factorization $36=2\times 18$ which gives $a=\pm 8$ and $b=10$. So there are two integers $a=8$ and $a=-8$ with the required properties.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
