Maximum and minimum transverse speeds at an antinode
In summary: This can be a bit confusing because usually velocity is measured as distance over time, but for a standing wave the distance is fixed (wavelength) and the motion is in time (period).So, for a simple standing wave on a string, the peak of the wave will move up and down the string with a velocity that is equal to the distance between peaks (wavelength) divided by the time it takes for the wave to go through one full oscillation (period). This is why the formula v=w/k applies to standing waves as well as traveling waves.
Taniaz
364
Adjacent antinodes of a standing wave on a string are 15.0cm apart. A particle at an antinode oscillates in simple harmonic motion with amplitude 0.850cm and period 0.0750s. The string lies along the +x-axis and is fixed at x = 0.
the speed of the two traveling waves are 4.00m/s
Find the maximum and minimum transverse speeds of a point at an antinode.
v=Aωcos(ωt)
[/B]
I was just reading this post: https://www.physicsforums.com/threa...erse-speeds-of-a-point-at-an-antinode.218615/ and I couldn't understand why they've taken cos(wt)=1 and cos(wt)=0 as the bounds. If it's an antinode, wouldn't it be max at 1 and min at -1?
Secondly, their final answers were v max=0.712, vmin=4.36 x 10^-17 but if cos(pi/2)=0 then v=min will be 0, how did they get 4.36 x 10^-17?
Speed is the magnitude of velocity. Speed = |v|. So, you need to consider the maximum and minimum values of |v|.
You are right that the minimum speed would be zero. 10-17 is very small. I haven't gone through why they got this small number rather than zero. Probably some sort of "round off error".
Thank you for your reply!
Aw cos (pi/2) is directly 0 isn't it? because cos (pi/2) is 0?
Also, could you guide please me on this question: explain why the relationship v=w/k for traveling waves also applies to standing waves? It was a later part of this question.
Yes, that's right.
Hmm, standing waves don't really have a speed (they just oscillate while "standing" in one place). So, I don't quite understand how you can say that v = w/k applies to a standing wave. However, standing waves do have an angular frequency w and a wavenumber k. So, I guess they want you to show that if you take the ratio w/k for a standing wave, then you get the wave speed for a traveling wave.
One way to approach this is to remember that standing waves can be considered to be due to the superposition of two harmonic waves traveling in opposite directions, each with the same amplitude and the same w and k. So, you would need to show that the superposition of the two traveling waves produces a standing wave with the same w and k as the two traveling waves.
Likes Taniaz
Thank you!
"There's two important 'features' of the standing wave. 1) wavelength - the distance between peaks. 2) period - the time it takes for the wave to go through one full oscillation (at constant x).
You have 3 parameters (omega,v,k) and the equation omega=kv, so that means you have a choice for which two of these parameters you want to use to describe the two 'features'. Then the 3rd parameter is given by the equation.
The natural choice is to use omega to describe 2PI/period and use k to describe 2PI/wavelength. And then v is given by the formula. But you don't have to do it this way. You could use v to describe wavelength/period and omega as 2PI/period, then k is given by the formula. So it is your choice really.
In other words, the physical meaning of 'velocity' for a standing wave is wavelength/time"
What does he mean by the last part?
I think the author meant to write wavelength over period.
The idea is to retain a concept of wave velocity even though it is a standing wave. You can think of a simple standing wave as the sum of two identical waves with equal and opposite velocities. The magnitude of that velocity will be wavelength/period.
Related to Maximum and minimum transverse speeds at an antinode
What is an antinode?
An antinode is a point in a standing wave pattern where the amplitude of the oscillation is at its maximum. It is the point of constructive interference between two waves that are traveling in opposite directions.
What is the maximum transverse speed at an antinode?
The maximum transverse speed at an antinode is the highest speed at which a particle moves back and forth in a standing wave pattern. It is equal to twice the speed of the wave.
What is the minimum transverse speed at an antinode?
The minimum transverse speed at an antinode is the lowest speed at which a particle moves back and forth in a standing wave pattern. It is equal to zero, as the particle momentarily stops moving at the antinode before changing direction.
How is the maximum transverse speed at an antinode calculated?
The maximum transverse speed at an antinode can be calculated by multiplying the frequency of the wave by the amplitude of the oscillation. It can also be calculated by taking the derivative of the displacement function with respect to time.
What is the relationship between the maximum and minimum transverse speeds at an antinode?
The maximum and minimum transverse speeds at an antinode are inversely proportional to each other. This means that as the maximum speed increases, the minimum speed decreases, and vice versa. This relationship is a result of the conservation of energy in a standing wave system.
41K
