Maximum Area of a Triangle Using Double Derivative
In summary, the conversation discusses how to find the maximum area of a triangle using double derivative. Two different approaches are suggested - one using an equation for the area and the other using the altitude of the triangle. Both approaches lead to the conclusion that the triangle with the maximum area is half of a square.
Jenny1
Someone please help me with this question. I can't do and I have a calculus exam in the morning.
Re: Maximun Area of a Triangle Using Double Derivative
https://www.physicsforums.com/attachments/762
Let suppose that is symply L=1 and set $\displaystyle \theta$ the angle between the two side of length 1. The area is...
$\displaystyle A = \sin \frac{\theta}{2}\ \cos \frac{\theta}{2}$ (1)
... and You can maximise A forcing to zero the derivative of (1)...
$\displaystyle \frac{d A}{d \theta} = \frac{1}{2}\ \{ \cos^{2} \frac{\theta}{2} - \sin^{2} \frac{\theta}{2}\} = 0$ (2)
The (2) is satisfied for $\displaystyle \theta = \frac{\pi}{2}$ and that means that... $\displaystyle A_{\text{max}} = \sin \frac{\pi}{4}\ \cos \frac{\pi}{4} = \frac{1}{2}$ (3)The triangle with langest area is the half of a square!... Kind regards $\chi$ $\sigma$
Hello Jenny,
An alternate to chisigma's approach would be to let:
\(\displaystyle A(\theta)=\frac{L^2}{2}\sin(\theta)\) where \(\displaystyle 0<\theta<\pi\)
Now, equating the derivative to zero, we find:
\(\displaystyle A'(\theta)=\frac{L^2}{2}\cos(\theta)=0\,\therefore\,\theta=\frac{\pi}{2}\)
and so what is the length of $x$?
To ensure we have maximized the area, we see that:
\(\displaystyle A''(\theta)=-\frac{L^2}{2}\sin(\theta)\)
\(\displaystyle A''\left(\frac{\pi}{2} \right)=-\frac{L^2}{2}<0\)
Another approach would be to let $x$ be the base of the isosceles triangle, so we would need to express the altitude $h$ as a function of $x$ and $L$, and this can be accomplished by bisecting the triangle along the altitude to get two right triangles.
Can you find the altitude?
FAQ: Maximum Area of a Triangle Using Double Derivative
What is the concept of Maximum Area of a Triangle Using Double Derivative?
The concept of Maximum Area of a Triangle Using Double Derivative is a mathematical technique used to find the maximum area of a triangle given its base and height. It involves taking the derivative of the triangle's area formula twice and setting it equal to zero to find the maximum value.
Why is Maximum Area of a Triangle Using Double Derivative important?
Maximum Area of a Triangle Using Double Derivative is important because it allows us to find the largest possible area of a triangle with given constraints. This can be useful in various applications, such as optimizing the use of materials in construction or maximizing the area of a plot of land.
What is the formula for finding the maximum area of a triangle using double derivative?
The formula for finding the maximum area of a triangle using double derivative is A = (1/2)bh, where A is the area, b is the base, and h is the height. To find the maximum area, we take the derivative of this formula twice and set it equal to zero, then solve for either the base or height.
What are the steps to find the maximum area of a triangle using double derivative?
The steps to find the maximum area of a triangle using double derivative are:
  1. Write the area formula for a triangle: A = (1/2)bh
  2. Take the derivative of the area formula with respect to either the base or height (it doesn't matter which one you choose): dA/db = (1/2)h and dA/dh = (1/2)b
  3. Take the derivative of the derivative (known as the double derivative): d2A/dh2 = 0 and d2A/db2 = 0
  4. Set the double derivative equal to zero and solve for either the base or height.
  5. Plug the value you found back into the original area formula to find the maximum area.
What are some real-life applications of Maximum Area of a Triangle Using Double Derivative?
Some real-life applications of Maximum Area of a Triangle Using Double Derivative include designing efficient packaging for products, optimizing the use of materials in construction, and finding the maximum area of a plot of land for building purposes.
