Maximum detectable wavelength of a photoresistor
In summary, the maximum detectable wavelength of a photoresistor depends on its material and construction, with a typical range of 1100 nanometers. As the maximum detectable wavelength increases, the sensitivity decreases due to lower energy levels. This wavelength cannot be changed, but different types of photoresistors can detect different ranges. The maximum detectable wavelength and bandgap energy are inversely related, and this parameter is important in choosing the right photoresistor for different applications. Longer wavelengths may require a higher maximum detectable wavelength, while shorter wavelengths may require a lower one to achieve high sensitivity.
Rula
to increase maximum detectable wavelength of a photoresistor which is equal to
planck's constant/ semiconductor energy gap , we need to decrease the energy gap only
planck's constant cannot be increased or decreased, right?
Planck's constant can be considered just as constant as pi is.
thanks for your help ,
Best Regards
FAQ: Maximum detectable wavelength of a photoresistor
What is the maximum detectable wavelength of a photoresistor?
The maximum detectable wavelength of a photoresistor depends on its material and construction. Commonly used photoresistors can detect wavelengths ranging from ultraviolet to near-infrared, with a maximum detectable wavelength of around 1100 nanometers.
How does the maximum detectable wavelength of a photoresistor affect its sensitivity?
A photoresistor's sensitivity decreases as the maximum detectable wavelength increases. This is because longer wavelengths have lower energy levels, which results in fewer electrons being released by the photoresistor, leading to a lower change in resistance and therefore a lower sensitivity.
Can the maximum detectable wavelength of a photoresistor be changed?
No, the maximum detectable wavelength of a photoresistor is determined by its material and construction and cannot be changed. However, different types of photoresistors can be used to detect different ranges of wavelengths.
What is the relationship between the maximum detectable wavelength and the bandgap energy of a photoresistor?
The maximum detectable wavelength and the bandgap energy of a photoresistor are inversely related. The bandgap energy is the minimum energy required to release an electron from the valence band to the conduction band, and longer wavelengths have lower energies. Therefore, a photoresistor with a larger bandgap energy will have a lower maximum detectable wavelength.
How does the maximum detectable wavelength of a photoresistor affect its use in different applications?
The maximum detectable wavelength of a photoresistor is an important consideration in choosing the right type of photoresistor for a specific application. For example, in applications where longer wavelengths are present, such as in infrared remote controls, a photoresistor with a higher maximum detectable wavelength would be more suitable. However, for applications requiring high sensitivity to shorter wavelengths, such as in UV light detection, a photoresistor with a lower maximum detectable wavelength may be preferred.
