In summary, the conversation discusses the equilibrium of a suspended block with an ideal spring under the application of a constant force. The maximum displacement of the block from its initial position is determined to be X = F/K, which is twice the value mentioned in the book due to the block's inertia causing it to go further down after reaching maximum extension.
Fitz Watson
A block is suspended by an ideal spring of the force constant K. If the block is pulled down by applying a constant force F and if maximum displacement of the block from its initial position of rest is X then, find the value of X.
mg + F = XK + K(mg/K)
Let mass of block = m
Before applying F, the block is at rest. Let extension of spring here be a. So,
aK = mg
Hence, a = (mg/K) ... {1}
Now, after the block comes in equilibrium under F,
F + mg = (X+a) K ..... {2}
Solving {1} & {2} gives:
X = F/KBut, my book says that X = 2F/K
It does not say that it comes to equilibrium. The force is maintained as a constant.
But when it has reached maximum extension, doesn't it mean that now the spring force is equal to weight + external force applied. And that's why the block can't go further down
Not necessarily. Think about KE.
Likes Fitz Watson
Now that I rethink, will it be like after forces becoming equal, block will go further down due to inertia?
Yes.
Related to Maximum displacement in mass spring system
What is a mass spring system?
A mass spring system is a physical system that consists of a mass (or multiple masses) connected to a spring. The mass is able to move back and forth due to the elastic force of the spring.
What is maximum displacement in a mass spring system?
Maximum displacement in a mass spring system refers to the furthest distance the mass can travel from its equilibrium position (the position where the spring is neither stretched nor compressed). This is typically measured in meters or centimeters.
How is maximum displacement calculated?
Maximum displacement can be calculated using the formula x = A*sin(2πft), where A is the amplitude of the oscillation, f is the frequency of the oscillation, and t is time. The maximum displacement occurs at t = 0.
What factors affect the maximum displacement in a mass spring system?
The maximum displacement in a mass spring system is affected by the amplitude of the oscillation, the frequency of the oscillation, and the mass and stiffness of the spring. A higher amplitude and frequency will result in a larger maximum displacement, while a heavier mass or stiffer spring will result in a smaller maximum displacement.
Why is the maximum displacement important in a mass spring system?
The maximum displacement is important in a mass spring system because it determines the energy and motion of the system. It also affects the behavior and stability of the system, as well as its resonance frequency. Understanding the maximum displacement can help in designing and analyzing mass spring systems for various applications.
