Maximum endurance at higher altitude
In summary: Additionally, the change in air density at higher altitudes does not affect the other parameters in the equation, such as weight and wing area.
alexat
As a first year aerospace engineer student I had a problem today.
The question was :
Does the altitude effect the endurance of an aircraft (provided that the aircraft engines can generate enough trust at this higher altitude).
Maximum endurance is minimum fuel flow [N/s] F = Ct T
in a steady, horizontal, symmetric flight F = Ct D
D = Cd (1/2) rho V² S
D: Drag
T: Thrust
Cd: Drag coefficient
Cl: lift coefficient
Rho: air denisty
V: velocity
S: wing area
So higher altitude = lower density = lower drag = lower fuel flow = higher endurance.
But also true is that F = Ct (Cd/Cl) W and none of these parameters are effected by the altitude.
Which one is correct and why? And why is the other one wrong?
Kind regards,
Alex
Edit:
but V is sqrt (W*2*1/(S*rho*Cl))
so the rhos cancel each other out.
Is there a delete button somewhere?
The correct answer is that higher altitude will result in higher endurance because of the decrease in air density. This is because at higher altitudes, the air density becomes lower, resulting in less drag and therefore less fuel consumption. The other equation does not take into account the effects of air density on drag, so it is incorrect.
Related to Maximum endurance at higher altitude
1. What is maximum endurance at higher altitude?
Maximum endurance at higher altitude refers to the maximum amount of time an individual can sustain physical activity at an elevated altitude without experiencing fatigue or other symptoms associated with altitude sickness.
2. How does altitude affect maximum endurance?
At higher altitudes, the air is thinner and contains less oxygen. This decrease in oxygen availability can lead to decreased aerobic capacity and endurance, as the body must work harder to receive the necessary oxygen for physical activity.
3. Is it possible to improve maximum endurance at higher altitude?
Yes, it is possible to improve maximum endurance at higher altitude through proper training and acclimatization. This includes gradually increasing physical activity at higher altitudes to allow the body to adapt to the decrease in oxygen availability.
4. What are the risks associated with exerting maximum endurance at higher altitude?
Exerting maximum endurance at higher altitude can put individuals at risk for altitude sickness, which can range from mild symptoms such as headache and nausea to more severe conditions like high altitude pulmonary edema or cerebral edema. It is important to acclimatize properly and listen to your body’s cues to avoid these risks.
5. Are there any tips for maximizing endurance at higher altitude?
Some tips for maximizing endurance at higher altitude include acclimatizing properly, staying hydrated, avoiding sudden increases in physical activity, and taking breaks to rest and recover. It is also important to listen to your body and adjust your activity level accordingly.
  • Mechanical Engineering
