Maximum height at which a siphon can drain an open water tower
In summary, the maximum height at which you could have "y" to still drain the cup in this scenario is 10m, as atmospheric pressure is equivalent to 10m of water and any height higher than that would result in a vacuum forming at the high point. The velocity of the siphon can also be a factor in determining the maximum height.
Hereformore
61
If you have a water tower (basically a cup) open to the atmosphere, with a siphon (basically a straw) inside it as shown below: (sorry assume the height h extends to the bottom of the cup instead of only part way - would that change anything though?)
Then what is the maximum height at which you could have "y" to still drain the cup?
p = po + pgh
So my understanding here is that you have the pressure exerted by the atmosphere and the pressure exerted by the water here, which depends on depth. Since the water pressure only depends on height, even though the straw is outside of the water tower, at a depth H, there will still be a pressure pgH pushing down on the water.
The trouble is then, how to push the water up the height Y. That's entirely dependent on the atmospheric pressure right? Thas the only other force / pressure source i can see acting here. So since atmospheric pressure is equivalent to 10m of water, the max Y could be would be 10m i believe. Am i on the right track here?
Yes. What happens at the top of the syphon if you make Y too high?
Would there be a vacuum?
Also if water is coming out of the open end of the siphon this couldn't really last right? Because as water comes out, the height Y that atmospheric pressure must be able to push water up the tube gets larger.
How interesting. So if I cover up the left half of the figure, I see a column of water with height y+h and P0 pressure at the bottom. If y is 9 m and h is 9 m too, then what about the pressure in the top 8 m of the tube ?
CWatters said:
Perhaps have a look at how an old mercury barometer works. They use mercury instead of water so that they don't have to be >10m tall.
http://weather.about.com/od/weatherinstruments/a/barometers.htm
Oh I see! So the opening of the siphon feels pgy + pgh. Pgy must equal atmospheric pressure.
So the height y = when pgy = 1atm. If the column is higher then the fluid can't riser higher. On the right side, from the ground, since the opening has atmospheric pressure, the column should spill out until the height of the water left is equal to y right? It shouldn't matter whether the opening is pointing horizontal or vertical since it still feels 1atm.
I may have just confused myself. The pressure of the water LEAVING a horizontal opening should be 1atm. The atmoshperic pressure should be one 1 atm as well going into the tube (just like how a damn feels presure horizontally). Yet the water is still flowing out. So water can still flow even though the presure is equal?
Related to Maximum height at which a siphon can drain an open water tower
1. What is the maximum height at which a siphon can drain an open water tower?
The maximum height at which a siphon can drain an open water tower is approximately 34 feet (10.4 meters).
2. How does the height of the water tower affect the maximum height at which the siphon can drain?
The height of the water tower does not affect the maximum height at which the siphon can drain. As long as the siphon is submerged in the water and the height difference between the two ends of the siphon is less than 34 feet, the siphon will work.
3. What factors can impact the maximum height at which a siphon can drain?
The maximum height at which a siphon can drain can be impacted by various factors such as air pressure, temperature, and the density of the liquid being siphoned. These factors can affect the flow rate and the efficiency of the siphon.
4. Can a siphon work at a height greater than 34 feet?
No, a siphon cannot work at a height greater than 34 feet. This is because the weight of the liquid in the longer leg of the siphon will exceed the atmospheric pressure and break the siphon.
5. Can the maximum height at which a siphon can drain be increased?
Yes, the maximum height at which a siphon can drain can be increased by using a larger diameter tube or by decreasing the air pressure in the upper end of the siphon. However, these methods have limitations and the maximum height is still limited to approximately 34 feet.
