Maximum Likelihood Estimator for a function
In summary, we are considering a density function of the form f(x) = ABB/xB+1, where A and B are positive constants. We are asked to find the maximum likelihood estimator for A, but after differentiating and setting to 0, we find that there is no solution for A. This may be due to the fact that the original density function was raised to a power and there is missing context about the problem.
ych22
115
Consider the following density function:
f(x) = ABB/xB+1; A<= x, zero elsewhere, where A > 0 and B> 0
f(x1,...,xn)= ABnBn(x1...xn)B+1
ln f(x1,...,xn)= Bn ln A + n ln B + (B+1)ln((x1...xn)
After differentiating with respect to A and setting to 0, Bn/A= 0. Therefore there is no maximum likelihood estimator for A?
Where did all of the different "x"s come from? You seem to have your original density function to a power. Why?
Also please state the entire problem. Are you asking for the "maximum likelihood estimator of A?
Related to Maximum Likelihood Estimator for a function
1. What is the Maximum Likelihood Estimator (MLE) for a function?
The Maximum Likelihood Estimator (MLE) is a statistical method used to estimate the parameters of a probability distribution by maximizing the likelihood function. It is commonly used to find the most likely values for the parameters of a function based on a set of observed data.
2. How does the MLE work?
The MLE works by finding the values of the parameters that make the observed data the most likely to occur. This is done by calculating the likelihood of the data for different values of the parameters and then choosing the values that give the highest likelihood.
3. What are the assumptions of the MLE?
The MLE assumes that the data is independent and identically distributed (IID). This means that each data point is unrelated to the others and is drawn from the same probability distribution. It also assumes that the data is continuous and that the function being estimated is well-behaved.
4. What are the advantages of using the MLE?
The MLE has several advantages, including being a widely-used and well-studied method, being relatively easy to implement, and producing unbiased estimates. It also has good asymptotic properties, meaning that as the sample size increases, the estimates will approach the true values of the parameters.
5. Are there any limitations to using the MLE?
One limitation of the MLE is that it requires the data to be continuous and have a well-defined probability distribution. It also assumes that the data is independent and identically distributed, which may not always be the case in real-world scenarios. Additionally, the MLE can be sensitive to outliers in the data, which can affect the accuracy of the estimated parameters.
