Maximum magnetic field from moving charge
In summary: The perpendicular component of E and B in a frame stationary with the charge is easy, E points away from the charge, and B is zero. Applying the transform, I don't see how one would get the result you describe above.
KeeperOfKeys
Looking at the fields that result from a uniformly moving electric charge, derived from the Lienard-Wiechert potentials, you find that an observer at a right angle to the direction of travel will see a magnetic field proportional to ##\beta (1 - \beta^2)## suggesting a maximum field at ##\beta = 1/\sqrt 3##.
Can someone help me understand on an intuitive level why it doesn't continue to increase with velocity?
I haven't seen that result before, and I'm a bit suspicious of it, so the first think I'd do is verify it.
The E and B fields when combined properly form a tensor. That means you don't have to recompute the E and B fields when you change your frame of reference from a stationary to a moving one, you simply have to transform them. If you know the E and B fields at a point in one reference frame, you can find the E and B fields at the same point in another reference frame.
Wiki gives the transformation laws in http://en.wikipedia.org/w/index.php...gnetism_and_special_relativity&action=history, other sources should give equivalent laws. There's a tensor form of the law, but it may be easier to work with the non-tensor version.
Finding the perpendicular component of E and B in a frame stationary with the charge is easy, E points away from the charge, and B is zero. Applying the transform, I don't see how one would get the result you describe above.
Not being familiar with your result, my first impulse would be to look at it more closely. It's possible I've made some silly mistake,, though I think there are other reasons to suspect your result, I don't see how it could be consistent with the Biot-Savart law.
Hmmm, I’m having trouble spotting my error, but it seems my calculation from the LW potential doesn’t agree with the field transformation approach. I’ll be the first to admit my knowledge of relativistic EM is shaky.
I’ll walk through my derivation and maybe you can help me catch my mistake.
My starting point is here:
http://en.wikipedia.org/wiki/Liénard–Wiechert_potential#Equations
Specifically the equation for B
Right off the bat I drop the second term since I assume velocity is constant, leaving
## \mathbf{B}(\mathbf{r}, t) = \frac{\mu_0}{4 \pi} \left(\frac{q c(\boldsymbol{\beta} \times \mathbf{n})}{\gamma^2 (1-\mathbf{n} \cdot \boldsymbol{\beta})^3 |\mathbf{r} - \mathbf{r}_s|^2} \right)_{t_r} ##
I am going to assume ##\bf{n}## and ##\bf{\beta}## are perpendicular giving:
## \mathbf{B}(\mathbf{r}, t) = \frac{\mu_0}{4 \pi} \left(\frac{q c \beta}{\gamma^2 |\mathbf{r} - \mathbf{r}_s|^2} \right)_{t_r} ##
And, just to make life easier, I can choose my radius from the direction of travel to be small so ##t_r = t##
Express the ##\gamma## with ##\beta## and you get the offending result.
This was interesting, I had not been aware of this before, but I looked into the Lienard-Wiechert potentials in detail and found exactly what you described.
The effect is due to relativistic aberration. The maximum field increases without bound as ##\beta \to 1##, but the direction where that maximum field points becomes more and more tightly collimated towards the direction of travel. So if you fix the direction then you will get a speed beyond which the maximum field has "passed" and gone to a tighter angle.
For easy reference, the angle of the maximum field is:
$$\theta = \arccos \left( \frac{-1+\sqrt{1+24 \beta}}{4 \beta} \right)$$
which goes to 0 as ##\beta \to 1##
The magnitude of the magnetic field at that angle is:
$$\sqrt{\frac{512 \left(\beta ^2-1\right)^2 \left(-4 \beta ^2+\sqrt{24 \beta
^2+1}-1\right)}{\left(\sqrt{24 \beta ^2+1}-5\right)^6}}$$
Which increases without bound as ##\beta \to 1##.
I'm not postiive yet I'm not the one making a mistake ...
Are ##\bf{n}## and ##\bf{\beta}## perpendicular at the retarded time ##t_r##?
I.e suppose we use cartesian coordinates ##\bf{r} =## (x,y,z), with ##\hat{x},\hat{y},\hat{z}## being unit vectors pointing in the various spatial directions.. Let (beta) be a scalar and ##\bf{\beta}## be a vector. If we assume the motion is in the z direction, then we can write ##z =## (beta) t, and the vector value of ##\bf{\beta} ## will be (beta) ##\hat{z}##,
Now assuming we are trying to calculate the value of the B-field B at x=##x_0##, y=0,z=0, t=0 (did I understand the problem properly? Is this what we are trying to calculate?). Assuming this is what we're after, then ##t_r## will not be zero, it will be around but not quite ##-x_0/c##. Thus ##\bf{r}-\bf{rs}## will be in the ##\hat{x}## direction at t=0 and thus perpendicular to ##\beta## which is in the ##\hat{z}## direction, but at ##t=t_r## ##\bf{\beta}## and ##\bf{r}-\bf{rs}## won't be perpendicular. Note that ##\bf{n}## points in the direction of ##\bf{r}-\bf{rs}##, it's just normalized to unit length.
Steve Carlip showed in his paper "Aberration and the Speed of Gravity" (http://arxiv.org/abs/gr-qc/9909087) that the aberration effect cancels out for static fields like this one. Isn't that a contradiction?
No. Carlip showed that at each point the electric field points towards the non-retarded position of the source. He did not even calculate which direction had the maximum magnetic field magnitude. Conversely, I showed which direction had the maximum magnetic field magnitude. I did not even calculate the direction the electric field points.
Likes davek
My knowledge of this is a bit "rusty", but it looks rather suspect to me. And you even don't need to compare it with special relativity, just Heaviside will do (and SR agrees with his results). For 90° angle I find that B is proportional to ##v/\sqrt (1-\beta^2)##.
This was based on my textbook, directly from the equation for B. Compare also with for example:
https://en.wikipedia.org/wiki/Relativistic_electromagnetism#The_field_of_a_moving_point_charge
That description has an explanation for why there is no net aberration effect.
And from the equation there for E, using that B = v x E/c2 , I find again the above result.
But of course, I may also be mistaken! :p So I'll be gladly corrected too. :)
Working with the L-W fields is tricky, because of the retarded time. What is perpendicular at the retarded time, is not perpendicular now. For uniform velocity, a simpler direct equation for B is given in textbooks that results in ##B=qv/(r^2\sqrt{1-v^2})## for r perpendicular to v.
Note: I just noticed Harrylin's post. Everything he says is correct
Likes vanhees71
Related to Maximum magnetic field from moving charge
1. What is the maximum magnetic field that can be generated by a moving charge?
The maximum magnetic field that can be generated by a moving charge depends on the strength of the charge, its velocity, and the distance from the charge. This is described by the Biot-Savart Law, which states that the maximum magnetic field is directly proportional to the strength of the charge and its velocity, and inversely proportional to the distance from the charge.
2. How can the maximum magnetic field from a moving charge be calculated?
The maximum magnetic field from a moving charge can be calculated using the Biot-Savart Law. This law states that the maximum magnetic field is equal to the product of the charge, its velocity, and a constant known as the permeability of free space, divided by the square of the distance from the charge.
3. What factors affect the maximum magnetic field from a moving charge?
The maximum magnetic field from a moving charge is affected by the strength of the charge, its velocity, and the distance from the charge. Additionally, the presence of other charges or magnetic materials in the vicinity can also affect the maximum magnetic field.
4. What is the significance of the maximum magnetic field from a moving charge?
The maximum magnetic field from a moving charge is significant because it is essential for understanding and predicting the behavior of electromagnetic phenomena. It is also fundamental in the development of technologies such as electric motors, generators, and magnetic levitation systems.
5. How does the maximum magnetic field from a moving charge relate to other electromagnetic phenomena?
The maximum magnetic field from a moving charge is closely related to other electromagnetic phenomena such as electric fields, current flows, and magnetic forces. These phenomena are all interconnected and can be described by Maxwell's equations, which describe the behavior of electromagnetic fields.
