Priyadarshini
- 191
- 4
number of alpha hydrogens= number of no bond resonating structures
option 1: 3
option 2: 6
option 3: 8
option 4: 9
So the answer should be 4, right?
Ohhh right. I forgot to eliminate the symmetric structures! Thanks.Suraj M said:Did you eliminate the symmetric structures?
The maximum number of no bond resonating structures is a concept in chemistry that refers to the total number of hypothetical structures that can be drawn for a molecule using resonance theory. These structures are called "no bond" because they do not involve the breaking or forming of any actual bonds.
The maximum number of no bond resonating structures is determined by the number of resonance contributors, which is equal to the number of resonance hybrid structures that can be drawn for a molecule. This number is influenced by factors such as the number of atoms, the arrangement of atoms, and the types of bonds present in the molecule.
The concept of maximum number of no bond resonating structures is important because it helps to explain the stability and reactivity of molecules. The more resonance structures a molecule can have, the more stable it is, and the less likely it is to react. This concept also helps to predict the most likely structure of a molecule based on its resonance hybrid.
Resonance is the phenomenon in which electrons are delocalized within a molecule, resulting in the formation of multiple resonance structures. The maximum number of no bond resonating structures is directly related to the number of resonance structures that can be drawn for a molecule. The more resonance structures there are, the higher the maximum number of no bond resonating structures will be.
No, the maximum number of no bond resonating structures cannot be exceeded. This is because the number of resonance structures is limited by the number of valence electrons and the arrangement of atoms in a molecule. Any additional structures drawn beyond the maximum number would not be valid resonance contributors.
