Maximum number of orbiting planets
In summary, the number of planets that can orbit one Sun is not fixed and depends on the definition of a planet. In our solar system, there are currently 8 planets, but there could be more if they are located outside of Neptune's orbit or in a binary star system. The ability to form planets also depends on factors such as the mass and velocity of the material in the solar system, and the presence of other stars or objects that could disrupt the formation and stability of planets. The definition of a planet is not a clear-cut scientific concept, and the recent reclassification of Pluto as a "dwarf planet" highlights the ambiguity of this term.
Rothiemurchus
203
How many planets can orbit one Sun?
Astronomy news on Phys.org
There is no fixed limit. First you'd have to define a planet. I believe the IAU's definition only applies to our solar system. If a planet can be anything larger than a speck of dust, then the number for our sun is probably in the quadrillions.
Our solar system is said to be "dynamically full". That is, you can't place a planet inbetween any other two planets and have it remain stable for long periods of time. So for our solar system, you only hopes of adding more planets would be exterior to Neptune. And I believe there's room for one more interior to Mercury.
Our solar system stopped producing planets beyond Neptune because the disk of material didn't have enough mass at that distance, and or the orbital velocities are too slow at that distance to ensure that enough collisions take place.
Additionally, stars in binary systems have their stable zones limited by their binary partners, but there could be planets orbiting the pair of stars from a great distance.
And stars that spend too much time in star clusters can have their outer planets stripped away by close stellar encounters.
So its a function of a lot of things.
It also depends on what you mean by a planet!
There are a vast number of bits of rock / dust / ice orbiting the sun - calling 9 (now 8!) of them planets is a purely arbitrary distinction.
Yep, there's no truly scientific definition of "planet"...it's a spectrum of possibilities...although the IAU recently voted on a working definition which resulted in Pluto being redesignated as a "dwarf planet".
FAQ: Maximum number of orbiting planets
What is the maximum number of orbiting planets?
The maximum number of orbiting planets is not a fixed number and can vary depending on the specific planetary system. Some systems have been found to have up to eight planets orbiting a single star, while others may only have one or two planets. Additionally, some systems may have orbiting planets around multiple stars.
What determines how many planets can orbit a star?
The determining factors for how many planets can orbit a star include the size and mass of the star, the distance between the star and its planets, and the gravitational forces between the star and its planets. These factors can vary greatly between different planetary systems.
Can the maximum number of orbiting planets change over time?
Yes, the maximum number of orbiting planets in a system can change over time. This can happen due to various reasons, such as gravitational interactions between planets causing some to be ejected from the system, or the formation of new planets through accretion of debris in the system.
Is there a limit to the number of moons that can orbit a planet?
Similar to the maximum number of orbiting planets, there is no fixed limit to the number of moons that can orbit a planet. The number of moons can vary depending on the size and mass of the planet, as well as its distance from its star. Some gas giants, for example, can have dozens of moons in orbit.
Could there be a planetary system with no orbiting planets?
While it is uncommon, it is possible for a planetary system to have no orbiting planets. This could happen if the star is not massive enough to form planets, or if the planets were ejected from the system due to gravitational interactions with other bodies. However, most stars are likely to have at least one orbiting planet.
