Maximum possible current in a Conductor
In summary, the maximum possible current in a conductor is determined by its material, cross-sectional area, and length. It can be calculated using Ohm's Law and can be exceeded, causing damage to the conductor. Temperature can also affect the maximum current capacity. Lastly, the type and size of the conductor can vary the maximum possible current.
suchith
If we are given a metallic conductor in a given Temperature(Room temperature here), Area of cross section A, is there an upper limit to the strength of the current through such a conductor due to the upper limit for drift velocity(v)??
I=nAve
e=electron charge
n=electron density
hi there :)
google is full of wonderful answers here is one of them :)
cheers
Dave
What factors lead to limiting of maximum permissible current besides limit of drift velocity?
Related to Maximum possible current in a Conductor
1. What factors determine the maximum possible current in a conductor?
The maximum possible current in a conductor is determined by three main factors: the material of the conductor, its cross-sectional area, and its length. Conductors with higher conductivity, larger cross-sectional area, and shorter length will have a higher maximum current capacity.
2. How is the maximum possible current calculated for a specific conductor?
The maximum possible current in a conductor can be calculated using Ohm's Law, which states that the current (I) flowing through a conductor is equal to the voltage (V) divided by the resistance (R). This means that the maximum current is directly proportional to the voltage and inversely proportional to the resistance.
3. Can the maximum possible current in a conductor be exceeded?
Yes, the maximum possible current in a conductor can be exceeded. This is known as overcurrent, which occurs when the current flowing through a conductor is higher than its maximum capacity. Overcurrent can cause damage to the conductor, as well as other electrical components in the circuit.
4. How does temperature affect the maximum possible current in a conductor?
Temperature can affect the maximum possible current in a conductor in two ways. First, an increase in temperature can decrease the conductivity of the material, resulting in a lower maximum current capacity. Additionally, high temperatures can cause the conductor to expand, which can lead to an increase in its resistance and therefore a decrease in maximum current capacity.
5. Is the maximum possible current the same for all types of conductors?
No, the maximum possible current can vary depending on the type of conductor. Different materials have different conductivity values, which can affect their maximum current capacity. For example, copper is a highly conductive material and can carry a higher maximum current than aluminum. Additionally, the shape and size of the conductor can also affect its maximum current capacity.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Classical Physics
