Maximum pressure a hull can stand
In summary, the conversation discusses the maximum pressure a submarine hull can resist and calculations are made for a 2m diameter, 2m long steel tube. There is a consideration for a lack of internal support structure and the possibility of buckling as the failure mode. The conversation also mentions the use of corrugated walls and internal circular hoops as potential solutions to increase buckling resistance.
oxi
Hello,
First, please understand that I'm lacking fundamentals in physics and engineering.
I'm trying to find the maximum pressure a submarine hull can resist. For the sake of simplicity I'm just considering a tube closed with magical caps that keep a different pressure inside and outside.
After much research and a few calculations, I think I've gone wrong somewhere, because I'm getting that a 2m diameter, 2m long steel tube 1cm thick will plastically deform under the pressure at 114m depth only.
From here (http://www.calctool.org/CALC/other/games/depth_press) I'm getting that the pressure at 114m depth is 1.24723 MPa = 1,247,230 Pascals or Newtons/square meter
My magical hull is a tube 2.02m outer diameter and 2m long, again without caps, and keeping the pressure difference, and I guess the inner pressure would be zero. So its surface area should be: D x pi x height = 2.02 x 3.14 x 2 = 12.69m2
That'd mean it's getting a total force exertion of 1,247,230 x 12.69 = 15,827,349 Newtons / 9.8 = 1,615,035 Kg = 1,615 metric tons. (Which seems ridiculously high)
Then I'm calculating the yield moment using this (http://en.wikipedia.org/wiki/Section_modulus#Elastic_section_modulus):
S =
pi x (oD^4 - iD^4)
32 x oD
pi x (2.02^4 - 2^4)
32 x 2.02
3.14 x (16.64 - 16)
64.64
S= 0.031
If my hull is made of structural steel its got a yield strength of about 250MPa = 250,000,000 Newtons/square meter
Yield moment = S x yield strength = 0.031 x 250,000,000 = 7,893,642 Newtons/meter / 9.8 = 805,474 Kg/meter
Since my hull is 2m long, it should be able to withstand 1,610,947 Kg before plastic deformation occurs.
Where did I go wrong? And please remember that I have little physics/engineering background, so explain as you would to a child.
Thanks!
P.S.: Sorry for the format, but I can't bother to learn Latex or whatever it's used for writing equations just for one question.
You didn't.
I haven't checked every little bit of your calculation for arithmetic errors, or your figures for steel strength vs. mine, but you've come up with the correct order of magnitude (power of ten) and are easily within 20 to 30 percent of crush depth.
Well, there might be one error: you are assuming a submarine with no internal support structure.
Yeah, one pistol shrimp and it's done for --- but it's reasonable for a beginning look at hoop stress.
Should you worry about yielding or buckling? I assumed that buckling would be the mode you'd worry about.
Besides, are you imagining a failure under tension or compression.
Thank you!
So a simple tube wouldn't stand that much...
How is this support like? Is it pillars crossing the hull diametrically?
Should I be using these equations instead? http://en.wikipedia.org/wiki/Cylinder_stress
(Seriously, a shrimp? o_O)
I guess I'm looking at compression. I don't really know, but I'll have a read at this http://en.wikipedia.org/wiki/Buckling
Thanks!
P.S.: Excuse my English
For most hollow vessels under external pressure that I've come across, the ruling mode of failure has been bucking.
It's take a very short vessel for compression to be the relevant failure mode. I could be wrong.
:oldlaugh:
The hoop forces acting around a high pressure cylinder work out to be twice that of the axial forces due to the pressure on the ends of the pipe. That is why pipes tend to split along their length. A tube with a longitudinal flush welded seam will usually fail along the heat effected zone next to the seam weld. Some pipes are helically formed from a long narrow parallel strip of sheet material. The single folded seam provides increased hoop strength, while avoiding the weakness of an axial seam.
Open ended pipes can be made with a corrugated wall, see; http://www.atlanticcivil.com.au/hel-cor/
The properties of flat wall with a welded or folded helical seam. http://www.spiralmfg.com/downloads/physical_properties.pdf
Buckling is compressive failure. The cylindrical shape of a pressure vessel, with hemispherical ends, is designed to balance the forces. As pressure increases with depth a submarine becomes smaller. It is important that there are no members such as struts that cross from one side of the pressure hull to the other. Any rigid “point” or “longitudinal” attachments to the pressure hull would change the force distribution and result in the formation of a wrinkle and early failure. Any structural reinforcement would need to be in the form of closely spaced internal circular hoops. They would be designed to keep the hull cylindrical by preventing the formation of longitudinal wrinkles. Internal bulkheads would need to attach to the pressure hull in a way that does not behave differently to any internal hoop structure fitted.
A typical way to increase buckling resistance of cylindrical hulls is to reduce unstiffened length by adding stiffening rings I think. To some limit, the closer your stiffening rings the higher the external pressure your cylindrical hull can resist without buckling.
The same is true of surface vessel hulls. Vertical frames (and bulkheads) control the curvature of the external skin. Frames are spaced regularly along the axis of the vessel. Thinner plates require closer frames.
Here is an example of the structural skeleton showing through the stretched plates on the stern of an old ship. They have fixed the worst examples which were at the bow.https://www.pearlharbortours.us/home_rotor/8.jpg
Related to Maximum pressure a hull can stand
1. What is the maximum pressure a hull can withstand?
The maximum pressure a hull can withstand varies depending on several factors such as the material of the hull, its design, and the depth of the water. Generally, a hull can withstand pressures ranging from 3000 to 5000 pounds per square inch (psi).
2. What happens if a hull exceeds its maximum pressure limit?
If a hull exceeds its maximum pressure limit, it can undergo structural damage or collapse. This can lead to water flooding the hull, causing it to sink. It is crucial to stay within the recommended pressure limits to ensure the safety of the vessel and its passengers.
3. How is the maximum pressure a hull can withstand determined?
The maximum pressure a hull can withstand is determined through extensive testing and calculations. Engineers and scientists use various methods such as hydrostatic testing, finite element analysis, and computer simulations to determine the maximum pressure a hull can withstand.
4. Can the maximum pressure a hull can withstand be increased?
Yes, the maximum pressure a hull can withstand can be increased by using stronger materials, improving the design, or adding reinforcements. However, these alterations must be carefully evaluated and tested to ensure they do not compromise the structural integrity of the hull.
5. How does the maximum pressure a hull can withstand impact the depth a vessel can operate at?
The maximum pressure a hull can withstand directly affects the depth a vessel can operate at. The deeper the water, the higher the pressure, so vessels with higher maximum pressure limits can operate at deeper depths. However, other factors such as the purpose of the vessel and its equipment may also limit its depth of operation.
  • Mechanical Engineering
33K
  • Materials and Chemical Engineering
