Maximum pull-off load, axial load and radial load of two strapped pipes
In summary, the conversation revolves around calculating the maximum loads for a pipe strapped to a larger pipe using a steel strap and spacer block. Various variables such as the pipe diameters, separation, coefficient of friction, and strap dimensions are given. The pull off, axial, and radial capacities are discussed and their equations are shown. The final result is a calculation of the maximum load that the strap can withstand.
TW Cantor
54
Two pipes are strapped together using a single carbon steel band with a spacer in between. Assuming the larger diameter pipe is fixed, I am trying to calculate the following three scenarios:
The maximum pull off load away from the larger diameter
The maximum axial load (slip)
The maximum radial load (moment)
See text body
Imagine the following scenario. A pipe is strapped to a larger "host" pipe using a steel strap and a spacer block as shown in the image below. If anyone could have a look at my calculations to confirm they are correct that would be brilliant!
Variables
Assuming the following general values I would like to calculate the three maximum loads mentioned in the title:
Diameter of large pipe (DL) = 200mm
Diameter of small pipe (DS) = 125mm
Pipe separation C-C (Sep) = 200mm
Coefficient of Friction (CoF) = 0.2
Factor of Safety (FoS) = 1.5
Factor for Capstan effect (Cf) = 1.3 (loss in tension due to friction of band on pipes)
Strap width (Sw) = 30mm
Strap thickness (St) = 1mm
Strap Tensile Strength (σ) = 370MPa
Strap Tension (T) = 400kg
Strap Angle (θ) = 26.1° / 0.38rad
Pull off Capacity
The pull off capacity is defined by the yield strength of the strap. Rearranging the standard Stress = Force/Area equation gives a yield force for our strap material of:
Yield Force (Fy) = 370 * (30 * 1) = 11.1kN
Since the strap is at an angle, only a component of it is resisting the pull of the smaller pipe. The vertical component of this force is calculated using trigonometry. The force will act over two cross sections of band. Adding in a material utilisation factor gives the pull off force to result in strap yield is:
Fy * 2 * cos(θ / 2) * 0.67 = 14.6kN or 1489kg
Axial Capacity
The strap is pressing the smaller diameter pipe into the spacer, and then the "fixed" larger diameter pipe. Again since the strap is at an angle only a component of the tension is clamping the small pipe down:
Vertical component of strap tension (Tv) = 2 * T * cos(θ/2), which in this case equals 2 * 400 * cos(0.19) = 785.6kg
Max Axial Load = (Tv * CoF) / (FoS * Cf) = (785.6 * 0.2) / (1.5 * 1.3) = 80.6kg
Radial Capacity
The radial capacity is a bit more complicated to calculate.
Applying a load (L) as shown in the image below creates a moment force (MF) = L * Sep
The force required at the interface between the spacer and the larger diameter pipe to resist the moment (FRM) is: MF / (DL / 2)
Accounting for the friction, the clamp force (CF) required is: FRM / CoF
The strap tension required TR is therefore = cos(θ / 2) * CF / 2
Again accounting for FoS and Capstan effect, the tension required to resist load L = TR * FoS * Cf
Plugging in our values we can combine the equations to give:
T = (L * FoS * Cf * Sep * cos(θ / 2) ) / (CoF * DL)
400 = (L * 1.5 * 1.3 * 0.2 * cos(0.19)) / (0.2 * 0.2)
L = 41.8kg
Bump
Related to Maximum pull-off load, axial load and radial load of two strapped pipes
1. What is the maximum pull-off load of two strapped pipes?
The maximum pull-off load of two strapped pipes refers to the maximum amount of force that can be applied to the pipes before they become detached from each other. This is an important factor to consider in designing and constructing pipelines to ensure their stability and integrity.
2. How is the maximum pull-off load determined?
The maximum pull-off load is determined through a combination of laboratory testing and mathematical calculations. The pipes are subjected to increasing levels of force until they become detached, and this data is then used to calculate the maximum pull-off load for the specific type of pipe and strapping being used.
3. What is axial load in relation to two strapped pipes?
Axial load refers to the force applied along the length of the pipe, either in a pushing or pulling motion. In the context of two strapped pipes, axial load is an important consideration as it can affect the stability and strength of the pipes and their strapping.
4. How does radial load impact two strapped pipes?
Radial load refers to the force applied perpendicular to the length of the pipe, which can occur due to external pressure or changes in temperature. This type of load can cause the pipes to bend or deform, potentially affecting their structural integrity and the effectiveness of the strapping.
5. What factors can affect the maximum pull-off load, axial load, and radial load of two strapped pipes?
The maximum pull-off load, axial load, and radial load of two strapped pipes can be affected by various factors such as the type and quality of the pipes and strapping, the installation method, environmental conditions, and the level of maintenance and inspection. It is important to carefully consider and monitor these factors to ensure the safety and reliability of the pipeline system.
  • Mechanical Engineering
