mgkii
- 138
- 42
Hi - Can anyone help me out with a question. The answer seems obvious, but maybe so obvious that I'm jumping to wrong conclusions!
Just been reading Guy Martin's book "When your dead, your dead" (good read by the way) and one of his stories is about breaking the world speed record for a wall of death. I've looked at the math around wall of death mechanics and it all seems pretty straight forward, but here's what's puzzling me.
1. There's plenty of forces to worry about when riding the wall of death, but the one that appears to limit your speed is the G Force acting on the rider/bike as a result of centripetal force when you run at a constant "speed" - but constant acceleration in velocity terms around the inside of the wall.
2. The smaller the radius of the wall of death, the higher the G Force acting on the rider and bike, so if you want to go faster, you build bigger.
3. I've read a number of different sources to try and understand the basics of the forces acting on ride/bike and the diagrams all seem to ignore radius - or rather they remove the complexity of centripetal force due to acceleration around the circle, but look at the bike as the frame of reference using the (fake) centrifugal force. The upshot seems to be that as long as you generate sufficient "centrifugal force" by going fast enough, then you're going to stay on the wall.
4. There's also a torque factor involved. Because the force of gravity acting downwards on the bike is from the centre of mass, and the force of friction on the wall from the tyres is acting at a distance from the centre of mass, then you need to lean the bike "up" the wall to stop it falling over. A coupe of sites have a graph that show that the slower the speed, the more you have to lean - so the faster you go the more you can ignore this torque effect.
5. It would therefore seem that in principle there's no maximum limit to the size of a wall of death - as long as you can get sufficient speed, you can ride an ever larger wall. And the larger the diameter the lower the G Force acting on the rider for any given speed. So obvious, but presumably so wrong!
6. Case for the prosecution: Before Guy Martin kick starts his bike, they get someone that actually understands the math involved (!) and determine that the fastest Guy is going to get up to is 80 mph on a wall of a particular radius (around 150 feet) and, that at this speed/radius he will be subject to 6G (which is where he puts his limit of "almost blacking out"!)
So - my question is what am I missing? Given that Guy is after a world record and has access to bikes that can top 200mph; why build a wall that limits him to 80mph? What is the limiting factor in the radius of wall of death?
Thanks all!
Matt
Thanks all!
Matt
